Hi guys,
I've been hard at work making a small, single board hardware platform for stabilization/autopilot purposes.
The board is very small. Currently it measures 1.5"x1.1" (39mm x 28mm). It runs a 16Mhz Atmel Atmega328p.
Also, included on board are a 3-axis mems gyro, 3-axis mems accelerometer and a 3-axis magnetometer (no in the picture above).
Input voltages are 5v-16v.
The board can see use up to 16 I/O ports for PWM (in/out), external modules etc...
There's also a I2C header for external I2C units.
The alpha boards are already running a cut-down DCM code:
I'm planning to implement fist a version of the Ardupirates code.
If you're interested in one of these please drop me a line here or via email (erezraviv@gmail.com)
"less than an ounce"
C'mon Erez you can do better than that ; )
What's the precise weight? We, the nerds that makes stuff fly need to know this.
I think the MultiWii guys will like it:
http://www.multiwii.com/
http://www.rcgroups.com/forums/showthread.php?t=1261382
http://farm6.static.flickr.com/5099/5403542651_277728c392_z.jpg
Gyro: L3G4200D - 3-axis MEMS gyro.
Accel - ADXL345 - 3-axis MEMS. I might swap with a Freescale unit if it has the performance to match. Currently you can't beat the ADXL.
Compass - HMC5843. Tough to get my hands on these but they seem to perform really well.
More details on the sensors please
Impressive little board, worth keeping an eye on. I'd be interested what static position accuracy you can get (without GPS) when you finish the port.
http://www.eraviv.com/store/page2.html
The Ardu variants are based on Arduino. In my experience the programs tend to be a little hefty. I haven't completed the port so I can't say yet but most of the functionality should be available.
I think the advantages are not just the small size.
The sensors are integrated 3-axis mems sensors. That way they are very orthogonal. The communication with them is digital and not analogue so voltage variations do not drift them.
I think the biggest advantage is having it all in one board and not having to cobble together stuff from SF/Wii/HK gyros etc...
1
2
3
4
of 4 Next
