Here it is! Finally, the PixHawk Fire Cape (PXF) is ready for a wider audience and we've launched a crowdfunding campaign so that everyone can get theirs. We've been iterating through different generations over the last year and with the help of many, we are finally proud to announce the PXF starting at $100.
This board was born out Philip's hands and pushed by members of this community so it's just reasonable to try making it as affordable and accesible as possible. Some technical details:
Sensors
- MPU6000: 3-axis gyroscope, 3-axis accelerometer and temperature sensor.
- MPU9250: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor
- LSM9DS0: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor.
- MS5611-01BA03: Barometer that includes pressure and temperature sensors.
Connectors
- 3x LED indicators (Green, Amber and Blue)
- 2x serial UART ports (ttyO0 is not active)
- 1x CAN connector and transceiver
- 3x I2C ports
- 1x Buzzer
- 1x Safety switch
- 9x PWM output channels
- 1 PPM/S.Bus in
- 1x Spektrum
- 1x Power brick connector
- 1x Battery backup (1 LiPo cell)
- 1x ADC
- 2x GPIOs exposed (IO)
- 1x analogic pressure sensor (AIR)
Mechanical characteristics
- Size: 88.6 x 54.73 x 20.69 mm
- Layers: 6
- PCB Thickness: 1.62 mm
- Weight: 31 grams
Support the crowdfunding campaign of the PXF here.
I will advertise your cape.
I vote for BeagleDrone.
BBB is something someone has to find out, thus just Beagle is better. Drone tells what's all about.
Julian> I would never be totally confident that code on one device running the autopilot as well wouldn't freeze under load...
I too have been a bit apprehensive about that and the difference between Pixhawk/ a true RTOS like NuttX. But if Tridge could fly a plane on Linux and compile a kernel at the same time, that's good enough for me so I am in! Ethernet connectivity for one thing will be real nice ...
Are all three sets of gyros and accelerometers actually used and fused in the Ardupilot port?
Agree with Chris as well.
So, why is Fire in the name? Was there a Thermal Event in the design and testing at some point? ;)
I'm in for an Early Bird.
Hi Victor,
I also agree with Chris, how you present this is going to make all the difference as to whether you hit your somewhat ambitious target.
When you get the main Indiegogo page tweaked, go around and make announcements: BLOGS, Facebook references, links, wherever you can think of: Maker, Drone racers, RC Groups, Linux sites, everybody.
If you can actually get that many of them out there you will have seriously hit and surpassed the critical mass necessary to make this the next flight controller.
And I for one am really rooting for you!
How about BBBpilot?
You already have BeaglePilot and that is probably the best name, How about BeaglePilot Adapter or BeaglePilot Interface?
All the Best,
Gary
Excellent advice from Chris. B^3 Drone or Pixhawk B^3 could work too for the BeagleBone Black, which is typically abbreviated BBB.
Just a couple marketing tips to help this campaign hit its target:
Hi Victor,
I think the FW update should be supported on both MP and APM Planner 2.0. But if it's done for one then it will be ported to the other.
I just picked up one on the earlybird deal. So hoping you guys get the numbers, it came out to approx $150AUD which was my price point to buy.
Good luck!
Nice work!
Thanks @Randy. We started taking a look at APM Planner 2.0 and thought that might be a better option since it's multiplatform. Is there any reason why you suggested MP?
Victor,
Nicely done. In the dev team I think we've found the timing on this board is fine. I'm sure it will fly arducopter, arduplane, etc a-ok. We are very keen for the production of more Linux autopilot boards. I think another important step will be to make the upload process for the firmware (i.e. MP upload) super easy.
