Printed high speed AVC copter and crash
Hi all,
I thought I would share the copter I hoped/hope to fly at ACV this year. I wanted to try to see what speeds I could get from a quad. I also thought it would be interesting to see what I could to with a 3d printer. I have access to a Makerbot 2x and I was also adding a heated bed to a friends printer. So based on the maximum dimensions of the Makerbot I designed the quad you see above and rendered below.
The quad consists of 4 arms with a semi aerodynamic cross section that is angled forward by 60 degrees. The round nose holds a tennis ball and the bottom swings open using a servo to drop the ball. The battery is held in the center of the frame and the 4 esc's are recessed into the side of the body to provide them with cooling without adding too much drag. The copter is held together using screws and nylock nuts that are pressed into the plastic.
I did some basic calculations to try to get an idea of what angle I was going to be able to sustain. My calculations suggested that I should be able to maintain 60 degrees if the air frame drag stops the copter from moving fast enough to reduce the lift of the props. I found I had to make some guesses about the air frame drag (I used coefficient of drag of a tennis ball as a starting point) and the area of the copter (I think this may have been a little low). In the end I concluded that without wind tunnel testing and a much better understanding of propeller aerodynamics I wasn't going to get too much out of the calculations.
What I did get was a reasonable estimate of the power I was going to need from each motor, 700 W total or 175 W per motor. This was well below the 285 W the NTM 28-26A 1200 kv motors are rated at. It also looks like it may be easier to get higher speeds as the weight of the copter increases. This is because the increased weight means the copter must hold a lower pitch angle at a given speed because of the increased lift required to stop the copter from loosing altitude. I limited my pitch angle to -60 degrees to ensure the copter didn't get too close to gimbal lock. The calculation of the airflow angle over the arms as speed increases and the copter pitches forward. What I found is the airflow becomes dominated y the forward airflow very quickly. In my case the airflow is only 3 degrees off the 60 degree angle of the arms at maximum speed.
So I did an autotune and took the copter out to the local model club to see what I could do. I found the copter would accelerate very quickly and the frame was amazingly strong and ridged. While the flame wheel frame I tested the power train on would bend under full acceleration, the 3d printed frame was a rock. With the 45 degree maximum pids I couldn't take the throttle past about half way without climbing. So I checked over the logs for any obvious problems (other than the one I had) and increased the maximum angle to 60 degrees. I also found that I had to adjust the yaw pids to control the frame a high speeds because it wanted to turn the frame sideways to the airflow. This is a well known effect. Just shoot an arrow without feathers or fire a rocket without fins. I was able to adjust the yaw pids to keep the copter right where I wanted it in the following flight.
The following flight I was able to really wind it out. I was very happy with the performance of the copter. It wasn't getting up to the speeds I was hoping for but things were looking good. After about 3 minutes of high speed passes I saw a clear line of white smoke coming from the copter followed by...... unhappiness.
The front left motor was burning hot and the smoke was the insulation on the winding's burning off. The logs showed that the front left motor was pegged during each high speed run and there was obviously a problem with it. The logs also showed maximum velocity of 107 km/h but it was happy sitting at 90 km/h even into a small head wind. The props / motor / battery combination would max out at 126 km/h on a normal plane.
So overall I was pretty happy with the performance. And I can say that a quad can be very effectively 3d printed provided the arms are designed to take advantage of the strengths of 3d printing. In this case each arm and body section attached to it was 70 g. The strength was high enough such that I couldn't break a arm by trying to bend it in my hands.
So now I need to work out if I can print a replacement before I fly to AVC. I need to print 6 parts, each taking approximately 12 hours. So each is an overnight print and I have 6 nights before I need to leave.... I may need to fly the Y6 :(
Things to remember. (this is a "note to self" but I thought I would share)
Always check the position of the bell on the motor shaft and adjust it to get the optimal location. This problem sounds like a bearing problem in flight. This is also a good time to ensure the grub screw is tightened properly.
After the first flight check the motor output of the autopilot at maximum throttle to see if any motor is consistently maxing out before others. This is the tell tail sign of a motor or esc problem and would have saved me here. I didn't look at this because all the motors were brand new.... bugger :)
Always check every screw and prop before the first flight. This is where little things can go wrong.
Yaw stability in a copter will take a big load of the yaw controller in a high speed copter.
Comment by leonardthall on June 8, 2014 at 7:12am
Thanks Adrian :)
Sorry Tipu, I didn't see your post. Yeh I am happy to share the files but the most important part is how you set up the print and the support material. As you can see from the copter, there arn't many flat parts :) I will have to put together the Makerbot print setup I used to get the weight strength balance. I used about $15AUS in abs for the frame and probably a quarter that again in support material.
Comment by Greg Dronsky on June 8, 2014 at 7:54am
Do you think it is possible to repeat your print setup on a reprap printer with 20x20x18cm work area?
Leo, You used ABS, i think i would go with t-glasse (http://taulman3d.com/t-glase-features.html). It is a pett material, stronger and with minimal shrink factor. What do you think?
Waiting to try to print your design it is really awesome :)
Comment by Gary Mortimer on June 8, 2014 at 8:12am
After the competition guys, after the competition ;-)
Comment by Ray K on June 8, 2014 at 8:27am
Something that could work is printing with low infill  (like 7 - 15%) and no roof and then pouring in fiberglass epoxy resin such as Bondo and letting it harden.  Granted, this method is better suited for larger pieces and  isn't ideal for small shells like this, but it could work without infill for this.
Comment by Jason Short on June 8, 2014 at 1:42pm
Hi Leonard,
I'd be glad to try and print some parts for you. I have 3 12hour parts myself to print this week, But I could squeeze yours in if needed. Just send me the STL.
Jason
Comment by Justin Martin on June 8, 2014 at 2:15pm
Hello Leonard! Great work! I am amazed there have been so few that have taken an aero-approach to multi's. I am not personally very big on multi based FPV, but this guy would make an awesome high speed and all around fun platform! Having built speed-oriented CP conventional helis, this really spikes my interest.
Please release the STL files when you have some spare time.
Was it printed on a stock (stock build area) Makerbot x2? Just curious as I could see this being very popular for some people. After a bit of research it appears the X2's build area is 9.7"(W) x 6" (L) x 6.1" (H), if you utilized the full bed (diagonally) this would give you a max print length of 10.9". This being said, I am curious how adaptable it is to other 3D printers, which use more of a cubic build area. (IE, 8" x 8" x 8", which actually has a larger build area, and a max length of 11.3"). I assume it should be easily doable, just making sure that there wasn't anything finicky in the print that would cause it to be difficult on other printers.
Also, Just curious as to the reasoning for carrying a tennis ball, and the ability to release this tennis ball?
T3
Comment by healthyfatboy on June 8, 2014 at 3:22pm
Dropping the ball was part of the contest last year and I presume it is this year too since it's in his design.
Comment by Justin Martin on June 8, 2014 at 3:53pm
Oooh, duh! Totally slipped my mind! My mistake! I got so fixated on the speed aspect.
Comment by John Dennings on June 8, 2014 at 5:56pm
Very cool!
At 60 degrees pitch, wouldn't one start to have issues with GPS visibility?
Comment by leonardthall on June 8, 2014 at 8:32pm
Hi Greg and Justin, 200 is to small. I would need to do a redesign. I designed the parts to fit comfortably on the Makerbot as I figured it wasn't something people would be generally interested in building for themselves.
Hi Ray K, I used a 20% infill with this and it is plenty strong enough. If I had time to optimize the design I could reduce the weight by another 30 percent and still have enough strength. ABS is a good plastic and the only real weakness is the relatively poor adhesion between layers compared to along layers.
Hi John, yes very possibly but I haven't seen any sign of it causing a problem yet. GPS antenna's are very large field of view. (I design antennas for a living).
Comment
