Just a quick update this weekend. I've printed all the pieces, even got to the laser cutter to try cutting some of the body parts out.
Here are some images and a small demo of a non scientific flex test between a 3D printed part and an acrylic part.
previous post: http://diydrones.com/profiles/blogs/3d-printed-h-quad-build
Awesome mini H-quad and those are really good quality 3-D printed parts. Could you share exactly what 3D printer you used and approximate cost of printer setup. After seeing how good parts come out I'm edging closer to buying a printer but need to research price/quality.
@Neuro thanks for the recommendation, I'll give that a go. The acrylic is definitely brittle, I tried snapping one of the plates today and it was pretty easy to break.
For a small copter like this, my ABS prints have been quite rigid and held up in several crashes. Can't say the same for the props ;)
Looks great. I wonder if SLS parts aren't the way to go. they are far stronger/stiffer than printed ABS.
have you ever tried thick lexan its nearly indestructible where as acrylic will crack its also very paintable with rc car paint !
Finally shot some FPV with it:
3D Printed Foldable Micro H-Quad FPV from Hovership on Vimeo.
