Almost exactly one year after the first PX4 announcement, we would like to introduce our newest member of the family, Pixhawk! For those familiar with the existing PX4 electronics, it is the all-in-one board combining PX4FMU + PX4IO, combined with a processor and sensor update and a number of new features. The current board revisions will however remain in full service and active development and are fully compatible. Pixhawk is designed for improved ease of use and reliability while offering unprecedented safety features compared to existing solutions.
Pixhawk is designed by the PX4 open hardware project and manufactured by 3D Robotics. It features the latest processor and sensor technology from ST Microelectronics which delivers incredible performance and reliability at low price points.
The flexible PX4 middleware running on the NuttX Real-Time Operating System brings multithreading and the convenience of a Unix / Linux like programming environment to the open source autopilot domain, while the custom PX4 driver layer ensures tight timing. These facilities and additional headroom on RAM and flash will allow Pixhawk the addition of completely new functionalities like programmatic scripting of autopilot operations.
The PX4 project offers its own complete flight control stack, and projects such as APM:Copter and APM:Plane have ported their software to run as flight control applications. This allows existing APM users to seamlessly transition to the new Pixhawk hardware and lowers the barriers to entry for new users to participate in the exciting world of autonomous vehicles.
The flagship Pixhawk module will be accompanied by new peripheral options, including a digital airspeed sensor, support for an external multi-color LED indicator and an external magnetometer. All peripherals are automatically detected and configured.
Features
32 bit ARM Cortex M4 Processor running NuttX RTOS
14 PWM / Servo outputs (8 with failsafe and manual override, 6 auxiliary,
high-power compatible)
Abundant connectivity options for additional peripherals (UART, I2C, CAN)
Integrated backup system for in-flight recovery and manual override with
dedicated processor and stand-alone power supply
Backup system integrates mixing, providing consistent autopilot and manual
override mixing modes
Redundant power supply inputs and automatic failover
External safety switch
Multicolor LED main visual indicator
High-power, multi-tone piezo audio indicator
microSD card for long-time high-rate logging
32bit STM32F427 Cortex M4 core with FPU
168 MHz
256 KB RAM
2 MB Flash
32 bit STM32F103 failsafe co-processor
ST Micro L3GD20H 16 bit gyroscope
ST Micro LSM303D 14 bit accelerometer / magnetometer
MEAS MS5611 barometer
5x UART (serial ports), one high-power capable, 2x with HW flow control
2xCAN
Spektrum DSM / DSM2 / DSM-X® Satellite compatible input
Futaba S.BUS® compatible input and output
PPM sum signal
RSSI (PWM or voltage) input
I2C®
SPI
3.3 and 6.6V ADC inputs
External microUSB port
Power System and Protection
Ideal diode controller with automatic failover
Servo rail high-power (up to 10V) and high-current ready (10A +)
All peripheral outputs over-current protected, all inputs ESD protected
- Monitoring of system and servo rails, over current status monitoring of peripherals
Dimensions
Weight: 38g (1.31oz)
Width: 50mm (1.96")
Thickness: 15.5mm (.613")
Length: 81.5mm (3.21")
Availability
This announcement is a service to our users and developers to allow them to plan their hardware roadmaps in time, and to show what we're currently working on. The board will not be immediately available, but 3D Robotics is taking pre-orders for Pixhawk now, and will begin shipping in late October [Update 11/11: the current expected ship date is late Nov]. The price is $199.99.
@Robert,
I'm pretty sure this is like 100% PX4 compatible, which means it pretty much already completely works with APM:Copter.
I notice they even brought out the ADC's so even Sonar won't be a problem (Although we really should switch to I2C Sonar because of it's increased noise resistance).
I think Tridge has been testing as "FMU-2".
PPM-SUM is better for a number of reasons, not the least of which is reducing wiring vibration issues to vibration isolated flight controller board by reducing number of wires considerably.
Between FRSky, HobbyKing, Futaba, Spektrum Satellite and others, there are getting to be a lot of PPM-SUM options and in the long run it is just better to switch.
And even in the short run, the 3DR PPM-Sum encoder works fine, I am using it on my PX4, it's just a little power hungry.
I look forward to getting my hands one of these!
That said, those particular DF-13 series connectors really are a bad choice!
They are not rated for very many connection cycles (50 I think ) nor are they robust and can only accept very tender wires. These connectors are fine for internal connections in camcorders ....
3DR should have chosen a connector that is on par with the world or RC, maybe something like the Molex C-GRID connectors.
tried to order but check out says "unable to ship to this address..." shipping address is in Canada and worked fine for other items??? Please explain?
Well, that's pretty attractive looking.
So what are the comparisons between the old processor and the new one, and the new gyro/accels vs. the old ones?
Is Arducopter going to run on this thing right away or is there going to be some changes necessary for those new sensors? Do those sensors have internal filters which have proven so critical Arducopter?
Are cables availabvle? Would love to be able to really easily swap this for the 2.5 on one of my quads.
Chris: For people who don't have PPM-capable receivers, there will be an option for a PWM-to-PPM converter cable, based on this.
Gary: Stay tuned ;-)
Alex: it has both a built-in magnetometer and the option of a remote one. Software-switchable.
Wow, you really are kicking it up a couple notches, starting to really get serious.
I guess all that's really left (for this Christmas at least) is the brushless gimbal.
Great to see you guys managing to stay at the front edge of the curve.
Got to get the wiki caught up with you.
25
26
27
28
29
of 29 Next
