I like the idea of having a script to your ground station. It is a way to implement some logic that your original GUI does not enable directly. It can also enable integration easily with other dlls and modules far beyond the original scope of the Mission Planner. The first thing I asked myself about when I found this "treasure" is what were the available variables and classes that I can already access, well I could not find a clear list, maybe I am not good at googling -which is true-. So I opened the source and tried to figure out myself.
The main start here is Script.cs it is where the engine class and scope class exist. what we want here is the scope class, it is the INTERFACE point where you can LINK outter world with PYTHON script.
scope.SetVariable (varname, realobject);
Using above function you can add more objects to link with and define names for it in Python. See the below figure where all objects are defined - and where you can add more if u want.
I traced back the added classes MainV2.comPort, MainV2.comPort.MAV.cs, this, this that are mapped to MavLink.cs , CurrentState.cs,Script.cs that means any public variable of function in these classes can be accessed from python script.
Lets open Mission Planner and open the script window and check the above conclusion:
In the above image you can see Script.SendRC …. You can find this function in Script.cs
Same for cs.alt which should exist in CurrentState.cs
Now you can get all the functions you want from these classes, you can even add your own classes and functions.
I hope you find my small blog is useful.
Thanks,
M. Hefny
Hi
Seems that pygame is not supported on Iron Python.
pls check this https://metapep.wordpress.com/tag/pygame/
also thegoogle code link inside seems to be old for Python 2.6
I made some investigation for you .... make sure that pygame uses the same 32-64 python version check lib downloads and isse link.
Now I faced another issue related to path pygame definition and I used this apppraoch to define paths.
sys.path.append('C:\\Python27\\Lib\\site-packages')
sys.path.append('C:\\Python27\\include')
Now I got another error related to weak reference. most probably because iron python compiled with IRON PYTHON 2.6 and I use 2.7 library .... I will make more investigation and get back to you.
U welcome ..... I am happy when my work is useful... Thanks for the feedback :)
amazing work! Thank you very much!
@Bim - if I understand you correctly, you want to be able to write a short program outside of the Mission Planner (which will have access to some data from the quad) that will will then pass on new waypoints to Mission Planner.
If so, this was a challenge that we had a few months back. Here is a short description of how we were able to do that.
First, there are two bits of not-so-well-documented MP functionality that we used:
1) MP's ability to stream GPS information from the quad to any serial port. (Check out the reference here: http://planner.ardupilot.com/wiki/common-other-mission-planner-feat...)
2) The ability to send a new waypoint to MP through an http command (see Michael's post in this topic http://diydrones.com/forum/topics/apm-adaptive-flying-video-analysi...)
From point 1) above you can get position information back from the quad (all the standard GPS stuff like lat, lon, height, number of satellites, quality of fix, etc). It sends the information as a NMEA sentences - about 2 a second.
From point 2) you can send a the quad a new waypoint
To connect these we wrote a small Python program that:
You may be asking "but how can I get other information back from the quad (let's say air temperature)?"
That was a little more difficult and required a bit of hacking. We changed the APM code to send the information in existing and "unused" fields in the NMEA strings. Specifically, we used the HDOP (floating point) and the number of satellites (integer) fields. These fields are not used by MP, only recorded. This is not very difficult once you understand how the APM code works (it required only one line of code change).
I believe however, that the Python scripting inside MP has recently been upgraded, so much of what I have written here may already be out of date.
very happy to b able to contribute :)
Thank u
I would like to for sure.
MHefny: This is great! It's definitely time to flesh out the MP Python scripting documentation. Would you like to add this (or something else) to the manual? I can have the team give you edit access.
I'm trying this myself and am also not quite sure which Python libraries are supported (or even whether that is Python 2.x or 3.x) so it would be good to flesh it out.
@Jack sorry I could not get the question right.
but flight pathes are programmed in C++ inside arducopter board, and C# in mission planner and can be controlled using Python from the Python window. I hope this helps.
@Bim for Python this link it is a simple nice language.
however C# is not that easy but everything is achievable ... goodluck.
1
2
of 2 Next
