This is a quick how-to to get going with ArduPilotMega QGroundControl Integration. Note that this is a work in progress and that the gains/ waypoints sent to the apm are not currently setting the values in the autopilot. I'll be working today to hook these up. I could really use help debugging and coding though so I've posted this to get everyone else up to speed.
  1. Get ArduPilotMega mavlink branch: svn checkout http://ardupilot-mega.googlecode.com/svn/ArduPilotMega/branches/mavlink "pathtosketchbook"/ArduPilotMega
  2. Get Arducopter libraries: svn checkout http://arducopter.googlecode.com/svn/trunk/libraries "pathtosketchbook"/libraries
  3. Get Mavlink: git clone https://github.com/pixhawk/mavlink.git "pathtosketchbook"/libraries/mavlink
  4. Get QGroundControl: http://qgroundcontrol.org/downloads or build from source: git clone https://github.com/pixhawk/qgroundcontrol.git "base directory"/qgroundcontrol, if you build from source you will need to copy "pathtosketchbook"/libraries/mavlink to "base directory" or create a symbolic link
  5. Set sketchbook path for arduino to "pathtosketchbook", then restart arduino IDE.
  6. Create an APM_Config.h file as seen below.
  7. Compile and upload code to board.
  8. Start QGroundControl, select network, add link, set to comm port (/dev/ttyUSB* on linux, COM* on windows) and then set the baud rate to 115200 (if using GCS_PORT 3)
Here is some documentation:
APM_Config.h file:
#define DEBUG_SUBSYSTEM 0
#define FLIGHT_MODE_CHANNEL 8
#define FLIGHT_MODE_1 AUTO
#define FLIGHT_MODE_2 RTL
#define FLIGHT_MODE_3 FLY_BY_WIRE_A
#define FLIGHT_MODE_4 FLY_BY_WIRE_B
#define FLIGHT_MODE_5 STABILIZE
#define FLIGHT_MODE_6 MANUAL
#define GCS_PROTOCOL GCS_PROTOCOL_MAVLINK
#define ENABLE_HIL ENABLED
#define GCS_PORT 3
#define GPS_PROTOCOL GPS_PROTOCOL_IMU
#define AIRSPEED_CRUISE 25
#define THROTTLE_FAILSAFE ENABLED
#define AIRSPEED_SENSOR ENABLED
    The development team is pushing hard to have a new stable release soon. There have been some great flights on the beta branch but there are still a few kinks to work out.
    Sounds Great! I work exclusively on linux so you should be all set for HIL. I use the oooark scicoslab toolbox to talk mavlink to APM over Serial0 and then talk to qgroundcontrol on Serial3. http://oooark.git.sourceforge.net/git/gitweb-index.cgi
  • Awesome, thanks. I will keep an eye on the trunk. I just got my APM board a few days ago, and am developing under linux so I have no HIL. I will stay out of the main branch until I get a few flights under my belt. However, I hope to eventually help with development.
    Any chance another stable APM release will be coming out any time soon?
    The mavlink dev branch is the one in sync with the apm trunk. (git clone "mavlinkurl" -b dev) I have hil running right now with in flight gains etc. I'm debugging some issues with the imu and flight modes as we speak. I wouldn't fly apm trunk until you can get a good hil run going. Hopefully I"ll have that working for me tonight though. It was previously working but we made some eeprom changes.
  • Has anyone been maintaining the mavlink branch? I just tried to grab and build it using these instruction, but it seems to be out of date compared to the latest ArduCopter libraries. I did notice that the APM trunk has some mavlink code in it, so I am going to try to build it next. Is the APM trunk stable enough to try to fly with? I would really like to have qgroundcontrol(mainly in-flight gain tuning), but it is a beast getting all this stuff to build.
  • Baud rate 115200== gibberish
    Baud Rate 38400== CLI messages sometimes
  • Changed to GPS_PROTOCOL_HIL , the code compiled and loaded .
    I got the latest libraries ,and mavlink files just this morning .
    My APM doesn't seem to be sending any sensor data to qGCS, the serial link happens , and i get the ArdupilotMega CLI messages sometimes , other times just gibberish .
    Tha APM_Config.h is just as above .
    Im trying all of this on a Mac (10.6.5 ) , is that why it isnt working ?
    Try switching from GPS_PROTOCOL_IMU to GPS_PROTOCOL_HIL and make sure your libraries are up to date and you have the latest version of the mavlink branch.
  • hey when i compile the code i get :
    ArduPilotMega.cpp: In function 'void fast_loop()':
    ArduPilotMega:518: error: 'class AP_GPS_HIL' has no member named 'airspeed'
    ArduPilotMega:527: error: 'class AP_GPS_HIL' has no member named 'roll_sensor'
    ArduPilotMega:528: error: 'class AP_GPS_HIL' has no member named 'pitch_sensor'
    i do not get this error when i use the regular ArdupilotMega code (non ArduCopter).
    If you write the mavlink protocol bridge for UDB then it will work.
