Quadcopter Build Update
Just fresh from the waterjet cutter..
3689550457?profile=originalLeft to right: Stack-up pad, Centerplate, Landing Gear.
3689550407?profile=original
Quadcopter Arms
3689550316?profile=originalArm and the Centerplate bottom flange.
I am always impressed in the cut quality of waterjet cutter!
I haven't measure the actual weight of the frame yet.. (my guess will be around 500g). The landing gear is still also an experimental design.
Next step: Installing a Self-clinching nut for the screws and then off to the bending press!
  • This is a 1.5mm thick aluminum 3003. I am looking at a more affordable aluminum. thou 6061 is "aircraft grade" and maybe the best material for this, I think it is a bit overkill. In my computation, the whole frame weights aprox. 475g w/ landing gear. and 355g w/o the landing gear.
  • What is the thickness of the aluminium ???? And what kind of aluminium ?
    I was thinking about aluminium chassis ( i have a lot of aluminium from 0.5mm to 5mm lol ) but scared about the weight :/
    Let's see the final product ^^
  • Hi Doug,
    Yes I am yet to bend them. Just preparing the brake and jigs. I am planning to pud vibration pads in between arm-centerpiece connection to minimize vibration.
  • That is certainly a robust chassis.
    Build on!
    -=Doug
  • If you have sample picture of the kind of nut kindly send them in my email maybe I can help you find here too.
  • Thanks Jay.. I have a hard time finding suppliers for self-clinching nuts in the Philippines! Maybe I'll just order online.
  • looking good!
  • Thanks Morli. Will do.
  • Admin
    Looks Good. Keep taking pictures of the build.
