Like Eric, I also step up a suggest Hoax, No offence and I hope I'm wrong but the maths dont work to make this possible with current technology. If I'm wrong prove or explain it to me and I will buy one tomorrow.
Why a hoax? apart from tthe claimed time? This vehicle NEVER leans or twists or shakes, its just too stable and correct.. it makes propwash in the grass but not enough. unless the vehicle only wieghs a few grams. I suspect its supported by a nylon wire to take most of the weight from the props. I truly hope I'm wrong.
He may be using stolen Russian Antimatter technology....
http://diydrones.com/profiles/blogs/my-old-octadecacopter-18-motors
old fc with gyro+acc (no baro, no gps, no mag)
Dwgsparky
All files of this flight: ~ 24Gb :)
So maybe its just the 12min video of the flight at x5 playback speed is actualy only x2 and the clock is fake, which is easyer to fake !
iT´s MAGiC.
MAGiCos never tell the trick.
Jani.. whats the flight time of those.. based on battery size it seems like quite a long time when only running 8.9 amps
@Sergei just measured one of our test units here with custom motors and here are some results
4S 4000mAh, Weight 1397gr, 8.5Amp, 135W
3S 3500mAh, Weight 1255gr, 8.9Amp, 114W
jD-Simplex Quad (similar to 3DR quads)
3S 3500mAh, Weight 1363gr, 15.4Amp, 180W
jD-ArduCopter (Original)
3S 3500mAh, Weight 1166gr, 12.5Amp, 150W
None of these has any optimization done. They all default configurations with default settings and so on.
1
2
3
4
5
of 5 Next
