[These are Frequently Asked Questions about the current state of UAV regulation in the US. Regulations elsewhere are different, but here is a similar post giving the rules for Canada.]
Q: Are UAVs legal in the United States?
A: Under certain conditions, they are. There are two ways to legally fly Unmanned Aerial Vehicles in the "National Airspace", which is to say all but certain restricted areas: 1) Get a Certificate of Authorization (COA) from the FAA, a process that can take months or more. 2) Fly under exemptions granted to non-commercial ("recreational") flyers who adhere to certain restrictions. More detail is here.
Q) What are those restrictions for non-commercial UAVs flying without a COA?
A: You MUST do the following: 1) Stay below 400ft. 2) Maintain a "pilot in control", which is to say that you must always be able to take manual control and fly the aircraft out of danger (in general, that means maintaining line-of-sight contact with the aircraft). 3) Stay away from built-up areas. More detail is here.
Q) Who can apply for a COA?
A: Typically only government agencies (Law enforcement, Civil government, etc). This is not an option for a private individual.
Q) I've heard that the FAA doesn't allow unmanned aircraft with cameras and/or GPS. True?
A) No. Commercial use of aircraft with cameras is regulated as above, but aircraft flying under the recreational exemption may use cameras and GPS.
Q) What countries have more relaxed UAV regulations?
A) Australia and New Zealand are famously progressive in their UAV policies. Other countries, such as Mexico, have been know to be relatively friendly, too.
Q) What are the prospects for FAA regulations that allow amateur UAVs more freedom?
A) There is currently a rulemaking proceeding that aims to improve the regulations on UAVs. It will take a while; indeed, you shouldn't hope for anything before 2010-2012. There may be a special category for UAVs under 4 pounds, which may be more lightly regulated. But then again there may not. It's all up in the air, so to speak, and the forces that oppose amateur or commercial UAVs in the National Airspace are many and powerful. Speak up!
Q) What about universities and other students. Any exemptions for them?
A) Not automatically. But they may be able to get COAs more easily if they are federally funded and go through that agency.
Q) What if I break the rules?
A) Well, for starters, we don't want to hear about it here! We realize, of course, that people break the rules all the time on the assumption that if they use good judgment and stay away from built-up areas, they won't be caught. That may indeed be the case, but it will only take one cowboy flying a UAV into an airport landing zone and endangering civil aviation to set our hobby back by decades. So please don't do it! (Plus you could go to jail)
Q) Okay, I'm obeying all the rules. Are there any other guidelines for safe and responsible UAV operations?
A) Yes. RCAPA (the RC aerial photography association) has some excellent guidelines that are a great place to start.
Here is the link for the regulations in Canada:
http://www.tc.gc.ca/eng/civilaviation/standards/general-recavi-broc...
As you can read above, Transport Canada regulations are different if you plan to use your aircraft (max 35kg) only for recreationnal activity or for commercial projects. It seams that Transport Canada includes research and development projects in the commercial part of the regulation.
For commercial purposes (if you plan to take a video for the promotion of your shop, if you plan to sell a picture for tourism promotion, etc.), you need to apply for a Special Flight Operation Certificate (SFOC) where you "demonstrate the predictability and reliability of the unmanned air vehicle [...] in the desired environment".
From what I understood 4-5 years ago. You need to apply for a SFOC for every flight and the analysis is made on a case by case basis. A SFOC for a 2m helicopter flight over downtown Toronto will probably be really harder to obtain then a SFOC for your 10th flight of your foam glider in a field 100km away from any village.
For more info on commercial UAVs in Canada, you can visit the non-profit organisation called:
http://www.unmannedsystems.ca/
While we all want folks to be responsible and to work within reasonable guidelines, it is misleading to state that one is required to stay below 400ft.
AC 91-57 is the referenced document in this case, and I feel it is important to point out that an Advisory Circular (AC) is simply "Advice" from the FAA on what they feel would be best practices. It is not a regulation, and deviating from this advice will not result in specific consequences. Even in AC 91-57 the first paragraph states...
We all clearly want to be aware of any hazards operating our recreational model aircraft might pose, and to operate them with a healthy dose of common sense. But let's not cloud the waters with misinformation. There is not currently any regulation, FAR or otherwise that restrict the altitude at which we operate.
That said... if you often see full scale aircraft flying over the area you fly out of, then you will definitely want to limit your altitude to a safe level.
1
2
3
4
of 4 Next
