With all the talk of integrating drones into civilian airspace, there is need for better safety and GPS-agnostic navigation methods - visual navigation and obstacle avoidance is paramount to integrating drones (micro-aerial-vehicles, MAVs) into our cities and elsewhere, because external navigation aids cannot be relied on in every situation, and neither can pilot experience.
Visual navigation is the solution to these challenges, and we present an aerial robot designed from scratch and ground up to meet these requirements. We demonstrate several facets of the system, including visual-inertial SLAM for state estimation, dense realtime volumetric mapping, obstacle avoidance and continuous path-planning.
In search of better extensibility, and better fitness for the research goals I had pitted myself towards, I started working as a part of the open-source PX4 Autopilot development community in 2013. Aware of the limitations in the field, I started Artemis, my research project on visual navigation for aerial vehicles in 2014. Today, I'm happy to present our intermediary (and satisfying!) results.
At its very core, Project Artemis is a research project which aims to provide improved navigation solutions for UAVs.
Screenshot-from-2016-03-18-071002.png?width=973
All of the Artemis MAVs follow the same basic, distributed  system architecture. There is a high-level onboard computer, and a low-level embedded flight controller, typically a PX4 autopilot board, or similar derivative. The middleware of choice on the high-level companion computer is ROS (Robot Operating System) and the PX4 Middleware on the deeply embedded controller.
Software
Visual Navigation
Multiple cameras provide proprioceptive information about the environment, used for mapping and localisation. Forward stereo cameras are used to compute depth images in realtime.
disparity
All cameras are synchronised in time with respect to each other, and to the IMU (Inertial Measurement Unit) of the flight controller. Depth images are inserted into a volumetric mapping framework based on an Octree representation, and a 3D map of the environment is built incrementally onboard the vehicle.
3689686568?profile=original
We also use a SLAM (Simultaneous Localisation and Mapping) technique on our robot. The system continuously constructs a sparse map of the environment which is optimised in the background. Visual SLAM is globally consistent, and centimetre-level accurate unlike GPS, and works both indoors and outdoors. Tight fusion with time-synchronised inertial measurements greatly increases robustness and accuracy.
mapping
State Estimation
image.09Q5DY
The system is designed to navigate using all available sensors in the environment, which includes both GPS and vision outdoors and pure vision indoors. Since sensor availability is not guaranteed, a modular sensor fusion approach using a hybrid Kalman filter with fault detection is used to maintain a robust state estimate. Motivation to use all the information from all the sensors is that even if a particular subset or module were to fail, the overall system performance would not be compromised.
Obstacle Avoidance
The global volumetric map is used to continuously compute a collision-free trajectory for the vehicle. In operator-assist mode, the motion planner only intervenes if the operator’s high-level position commands could lead to a possible collision. In autonomous modes, the planner computes optimal trajectories based on a next-best-view analysis in order to optimise 3D reconstruction. The planner sends its commands to the minimum-snap trajectory controller running on the low-level flight controller, which computes motor outputs.
It is important to point out that this can be achieved *today* with open-source systems, albeit with some perseverance and experience. Better documentation on how to achieve a relatively close reproduction of our results is underway. It will be made available soon via the UASys website (http://www.uasys.io/research) and the PX4 Autopilot developer wiki (http://dev.px4.io)
Our open-sourced portions of the software stack are available here : www.github.com/ProjectArtemis
I will also be presenting a talk on Project Artemis and our software stack at Embedded Linux Conference at San Diego, CA. Please attend if you'd like to get an in-depth view into the system's workings! The presentation will aim to accelerate the introduction to the current state of the aerial vehicle market, and the several limitations that it faces due to limited technological breakthroughs in terms of consumer systems. Newcomers and existing developers / system integrators will get a chance to understand these limitations, and what embedded Linux systems can do for the field, including but not limited to visual (GPS-denied) navigation, mapping, obstacle avoidance and high-definition video streaming. The talk also aims to encourage the current open-source development communities, and how they can contribute better to improving the current state-of-the-art, be it with cross-middleware interoperability, modular and reusable software design or inexpensive and extensible hardware design.
Slides are available here : http://events.linuxfoundation.org/sites/events/files/slides/artemis_elc16_final.pdf
Learn more about my session at http://sched.co/6DAs and register to attend at http://bit.ly/1ZuUtiu.
3689686609?profile=original
3689686489?profile=original
Stay updated! -
Wesite : http://www.uasys.io
GitHub : https://www.github.com/mhkabir
Instagram : https://www.instagram.com/uasys/
Twitter : https://twitter.com/UASysOfficial
Facebook : https://www.facebook.com/UASys
Cheers,
Kabir
  • Yeah.. You know me, always looking for the Bugatti ;-)
    So the CPU/GPU alternative , as Kabir is demonstrating here might be a more realistic concept for a DIYer.
  • Much $bling$ Patrick :)
  • @ben
    Actually, there is a FPGA based Visual-Inertial Sensor that has been developed by the Autonomous Systems Lab (ASL), ETH Zurich and Skybotix AG. This sensor provides fully time-synchronized and factory calibrated IMU- and stereo-camera datastreams. Unfortunately this device is not commercially available now.
    Paper here
    3702217856?profile=original
  • There's an interesting explanation of the FPGA system in this paper here
  • @Kabir - have you considered using an FPGA board for multiple cameras, instead of an Intel i7 computer?
    Something like the DJI Matrice Guidance system, which also uses an FPGA and controls 10x camera modules + 5x Sonar modules + IMU all at the same time selectively. I read that the DJI Guidance uses an Altera Cyclone SoC (5CSEMA5U23) board. It would be smaller, more capable, cheaper than i7, and can then link to something like a Jetson or Pixhawk to issue flight commands.
  • @Kabir,
    Thanks for pointing me in the right direction, it really makes make more sense now ;-)
    I looked at the https://github.com/PX4/Firmware/blob/master/src/drivers/camera_trig...
    External camera-IMU synchronisation and triggering via FMU auxiliary pins
    @author Mohammed Kabir <mhkabir98@gmail.com>
    Holy Cow , you wrote the driver.. Wow... Integrating a fully functional Visual-Inertial Sensor  into a UAV is quite impressive and doing it at 17 is AMAZING !!
    I wish you the best at the Linux Embedded Conference
    PX4/Firmware
    PX4 Autopilot Software. Contribute to PX4/Firmware development by creating an account on GitHub.
    Thanks Oliver!
    @Patrick,The command client you quoted doesn't actually control each frame trigger. Trigger timing is done on the realtime autopilot (Pixhawk). The triggering is interrupt based, so hard timing deadlines can be maintained. The command client simply gives the Pixhawk the initial call to start/stop triggering alongwith extra information like exposure times and trigger cycle times.
  • Fantastic work, you are pushing boundaries further. Must admit I had trouble keeping coffee in the proverbial cup when I read this.
    Thanks for sharing and congratulations!
  • That is what I've been reading: http://e-collection.library.ethz.ch/view/eth:48374
