I thought I would use the Swiss Machine Pin Headers after reading on Sparkfuns website that they hold really well, which is what I wanted. Also the FTDI cable works as well(my own realization).
DO NOT USE THESE! They hold a little too well...
You can see in the pic above that they tend to bend when trying to pull off the shield from the ArduPilot, they can't bend a whole lot, or they break.
So I need to find my damn desoldering tool, and desolder ALL the machine pins off, and put in the regular headers that came with the shield. This doesn't shine a bad light on sparkfun and their products, they work really well, just not for this purpose... lolLast but not least, here's my ArduIMU V2:
So since the AP setup worked, I tried uploading some waypoints. I'm unsure what I am doing wrong, but I've only been able to get a successful write 3 times maybe. I have the com port set to 6, and have read the manual, troubleshooting, FAQ's, & searched the site, still having issues. I think I have it pegged to a sequence of steps I need to do in perfect order, or I will get a fail...
I also made a wiring harness for my ArduPilot that will connect with my ArduIMU. I loaded Doug's code, and the R17 code for the IMU on my V2 IMU. Hooked everything up, and tried to get a response from it, nothing much happened, but again, I believe it comes down to my procedure. It was late 2nite, so I wasn't very in tune with my thinking. I'll be doing more tomorrow, trying to get things ironed out.
Oh, and I'll also be uploading more pics and vids when I wake up tommorrow.
laterz...
One thing I'm not a fan of is having a to spend a varying number of minutes to grab a GPS lock because of traveling, hasn't been turned on in a good while, or any number of reasons. I figure this will be a perfect solution, and it turns out to be a nice option versus draining batteries. As an added bonus, it works with the DIY Drones official FTDI cable. =]
ArduIMU V2:
ArduIMU V1:
where yet!Randy
