Full carbon frame with sexy color , 6 ducted propellors, semi-waterproof, enough room for 4 5A 4s lipo's. maximum prop size is 12".
Props are fully protected, can bump into wall, tree, person, without breaking props or hurting people.
Empty weight is 3,7kg. Current set-up Axi 2804/22 and graupner 11x5" props. Still looking for a better combination though, for increased flight time.
thanks
both...but not to much on endurance...here you have calculator so do the math yourself... http://www.ecalc.ch/xcoptercalc_e.htm
Would an increase in pitch do anything to the endurance? or only lifting capabilities?
@Henri We're making it a bit lighter first, want to get the most out of it before selling them.
@Allen unfortunally no, i don't have an APM. However, it is a great opportunity. Maybe DIYdrones is willing to donate one for the cause ;-)
Your picure with the top removed shows a DJI Wookong status display mounted inside. Interesting. . . . Have you flown the copter with a DIY autopilot?
Very nice design. A bit on the heavy side but with proper motors and batteries shouldn't be a problem. When will you have some for people to buy?
We're working on the weight problem, trying to get it to 1kg (frame only) so it'll be 2,5kg in total. That should increase the flighttime (ecalc says 3700=7 min, 2500=12min) for 1 5Ah 4s lipo
It's a constant fight keeping a solid (heavy) structure versus less weight and weaker material..
Are you sure that the safety improvement factor justifies the decrease in efficiency? If you are concerned about flying near people then the overall weight & size of your hexa will still constitute a serious risk if it impacts a person, with or without the protector.
If its mainly to save props, its probably only worth it if you use 100% carbon fibre props.
Keep up the safety work though, that will help us all get better insurance rates in future.
I'd buy one. My PVC HexCopter is about that heavy and flies just fine. How do you make something like that?
@R_lefebvre Yep thats absolutly true. I have plans for making more aerodynamic struts, but they have to be aluminium welded, and thats out of my league...
@fab, thanks
@Wessie Will do!
@Emin_Bu you have a good eye for it, i made it together with Killy :) He is an absolute master with carbon fiber!
The aixbotix is just a peice of board with 6 holes in it, this hexa is as aerodynamicly formed as it can bee, beeing space-ship like also :)
