So, a month or so ago I told people about the crazy Talon airframe I had built and wanted to try and fly:
http://diydrones.com/profiles/blogs/what-have-i-been-up-to-since-i?xg_source=activity
Well, now I have it flying!!
I have written a bit more about the process of getting it working and what my thoughts are on it's performance : www.universalair.co.uk/content/talon-first-successful-flight
I know a couple of people at least were keen to see if it actually flew, I was a little skeptical it would be able to balance itself in the pitch axis myself!
I'll post another video shortly which shows some of the less successful flights, where it didn't quite manage to balance!
One of the biggest problems seems to be the landing gear.
Next challenge: Transistion and conventional flight :D
Haha! Yes, I know what you mean James! Though now I'm just thinking along the lines of starting to approach the issue simply....I'll throttle up and fly directly upwards, to get airflow over the wings and see how that works...then if it all goes pear shaped I can still immediately start hovering again!
When I'm confident enough that it is flying like a standard fixed wing I'll try leveling out! Then I'll work out the tricky in between bit for efficient, low altitude, automated, transition when I have both ends working fine!
Nice job, I can't wait to see how you get it to transition!
Jason,
Didn't do any more tuning, but couldn't resist trying it outside:
Not immensely stable, but there are a lot of wind eddies around the garden, caused by the buildings and shrubbery, and the wing area means these have quite a large impact on the airframe.
Hello Roberto!
Yes, that looks a brilliant craft! How did you find transistion from hover to forward flight? We'll be embarking on some attempts to do that soon!
Warmest Regards!
Henry
Hi Henry,
you are doing a good work , check our work the solution is very similar but we decide to use a biplane configuration in our Fox Hybrid :) It fly first time one year ago. The video of flight start at 7.30 minutes
http://www.virtualrobotix.com/video/test-fox-hybrid-v2-14112010avi
Best
Roberto
