Skwalker X8 catapult
With the amount of equipment in my X8 is on the increase, so is the weight. Its becoming very difficult and somewhat dangerous to hand launch.
Iv decided to build a catapult. I dont like the idea of a bungee launcher because of the amount of flat space required. some places I fly dont have this.(eg: off a cliff =) ) I really wanted something self-contained and foldable.
The APM flies the X8 really well BTW =)
If anyone wants to build one I have posted all the info and pics here
3689500475?profile=original
3689500430?profile=original
  • Richard:  Regarding the need for the carriage to pull through all the way to the end (to avoid the slow down at the half way mark) I wonder what would happen if you took a hybrid approach to the bungee/tubing?  What I mean by this is, how would it work if you kept the two double bungees from one end to the other, but also added two more bungees that stretched from the back end around the pulleys and back to the carriage?  This will give you a firm thrust from the release and the two that stretched around the pulleys wil have enough tension to continue the carriage travel to the end of the track.   Just an idea...
    Bret C
  • Looks like it needs at least double the power...
    What keeps it in the cradle when you power up? Just friction? I like the design overall and would like to make a modified version for my 6lb Super Sky Surfer!
    Nathaniel ~KD2DEY
  • That looks awesome Richard! thanks for sharing your build. Will you be lauching an X8 too? very keen to see it launch!
  • Have you tried to launch this in Auto or Stabilize mode? Is the APM able to deal with the large acceleration numbers?
  • Chad, there is a link on the blog post to my build thread.
  • Please add a bill of materials and some drawings!!!
  • Nicely done indeed!  Thanks for posting your data!
  • Very cool..I like this one.
  • Thanks Andrew. As far as I can remember I'm logging everything possible so I will have look at the logs. Else I will make sure it's logging next launch.
