The new small size UAS Skyhooks 1700 UAV
It's made in strong white EPO foam just like most hobby models these days.
Wingspan: 1718mm
Body length: 1100mm
Wing Area: 45.5dm2
Empty Weight: 1050g
Material: EPO Foam design
0.2-0.3:1 Thrust to weight ratio.
Easy to assemble and disassemble.
Easy to transport.
This plane carrying 4s battery the take off weight is only 2.4KG if installing full line of FPV equipment take off weight is roughly 3KG.
When flown properly this plane can have more than one hour of flight time.
SKYhooks 1700 UAV
What you get:
Comment by Rob_Lefebvre on August 6, 2013 at 10:01am
So what about the 4S 5000?
Comment by Rob_Lefebvre on August 6, 2013 at 10:04am
I love the fact that it has a wheel on the belly to help it belly land without wearing on the foam constantly.  But, it's not to the extent that it has actual landing gear which can be draggy, and fragile.
Comment by Robert Krogh (hooks) on August 6, 2013 at 10:33am
There should be no problem having more than 5000 mAh 4S inside.
Gary@ I will tell you in 5 days. To me the fuselage looks a little thin in construction so it might have to have a thin layer of composite.
Well I think it will get a thin layer no matter what.
Comment by Rob_Lefebvre on August 6, 2013 at 10:38am
Oh wow, that picture makes it look much bigger than I thought!
Comment by Gary Mortimer on August 6, 2013 at 10:56am
I think the wheel with get in the way of the launch, they bungee the real ones so I bet this will struggle from the hand when loaded. That said I fancy one as well.
Comment by Robert Krogh (hooks) on August 6, 2013 at 11:13am
Agree. If loaded it with 3 kg electronics and lipo I bed a hand launch would need an oversized motor setup. Then again we like oversized stuff.
Comment by Steve K on August 6, 2013 at 11:24am
hi guys, just paid for one... Robert when are they shipping? as in do you have stock?
Steve
Comment by Steve K on August 6, 2013 at 11:29am
also the camera should be perpendicular to the fuselage.... so can you fit a Nex 5N in there perpendicular? or do I have to cut and widen the fuse in that section?
Comment by Robert Krogh (hooks) on August 6, 2013 at 12:14pm
Steve@ you will have your tracking number tomorrow. There is still a few left from the first batch.
I really don't know if you can fit in a Nex 5N, but i'm sure you will be the first to know.
Comment by Steve K on August 6, 2013 at 1:06pm
awesome thanks for actually having stock!
I imagine I have to do some mods
can you tell me be weight of foam an spars and wood only? I won't be installing landing gear etc
Comment
