Thanks to Hooks for turning us on to the new Skywalker foam UAV platform. Mine just arrived and based on a quick inspection, I'm pretty sure this is the one for me! Everything about is totally optimized for a UAV, from the payload capacity to transportability. I'm blown away by how thoughtfully designed this one is.
It's got it all:
- The durability of foam with all the interior room of balsa
- Payload area right under the CG, so you don't have to worry about balance issues
- Hand launchable, but still can carry pounds of payload
- Breaks down easily for transport
- Ailerons and optional flaps
- Pusher, high-wing configuration, with servos outside to save room inside
- Super tough EPO material
- Easy to get to equipment with big bay doors on both sides
- External mounting spots on rear fuselage for wireless transmitters (keeps them away from other electronics)
Here's a shot of a prototype being flown by the creators:
Rather than give it a full review (I haven't flow it yet), I'll just give first impressions in pictures.
http://www.rcgroups.com/forums/showthread.php?t=1223595
http://www.rcgroups.com/forums/showthread.php?t=1381499&page=3
http://www.rcgroups.com/forums/member.php?u=313616
http://www.rcgroups.com/forums/showthread.php?t=1309106
http://www.rcgroups.com/forums/showpost.php?p=15331784&postcoun...
http://www.rcgroups.com/forums/showthread.php?t=1290637
This is going to be a hard hobby if you don't learn google-fu
Hi all,
I just want to start my journey in the UAV world. I've decided to use skywalker as my first plane. Since I just learned to fly, i need advice about the all part that best to fit for skywalker. All advice on battery, motors, TX/RX etc...
Fikri
look at the picture of the wing you can see the wire channel and servo pocket , i have one and it is molded for a cut clearance at each end of flap and it is already hinged by the molding process for cut to activate use . just like all the other control surfaces on the kit . it is a very nicely engineered plane and kit in how it is setup with some small touches like the payload doors molded in light profile ready to be cut out and very simple assembly all with no assembly manual ;-)) but very easy
Any thoughts anyone?
Very short period.
Where is the altitude on the onscreen display?
Factory will make it in PVC. It's too early for me to show anything about the standard belly/cover nose.
Hooks.
