Skywalker X5PRO is professional aircraft that we intend to design this as whole set. It has whole equipment, including ground station, camera, catapult.
If you have any question, you could contact with me.
Skywalker X5PRO is new well-built professional aircraft for mapping survey, proceeding aerial survey task automatically without any intervention. Through a series of optimal design, it is stable and reliable, easy operation that could complete outdoor work. The cabin has moduel equipment and reasonable distribution that is easy to disassemble and assemble, maintainance and operation, decreasing its cost.
Technical Data Model: RF-5m Wingspan:1280mm Fuselage length:717mm Flying weight:2.4kg Take off: Catapult shot Landing: Parachute Wind resistance Level: Grade 4 Cruising speed:65km/h Duration of flight:55min Maximum flight height:5000m
Flight Control System--Skywalker It is equipped with professional flight control system, including high accuracy MENS sensor, GPS receiver and high performance processor, allocating special control caculation to realize stable flying.
More detail under this link:https://www.rcgroups.com/forums/showthread.php?2918668-Skywalker-X5...
Model: RF-5m
Wingspan:1280mm
Flying weight:2.4kg
Landing: Parachute
You could see and undertand more under the video on the Youtube:
http://diydrones.com/profiles/blogs/skywalker-x5pro-whole?xg_source...
Enter this link and see the video on the Youtube.
Camera
Model No.: Sony QX1
Sensor dimension:23.2*15.4(mm)
Effective pixel:(5456*3632)2010 Mega-Pixels
Camera data:20mm fixed focus lens
Professional backpack
Flight spot
There are more picture in the above video.
Picture generation
