Everytime i launch my X8 it's never any problems. That was until i mounted a bigger propeller. I went from 13x6 to 14x9.5 and my plane "suddenly" went out of my hand much faster than before! The result is a painful hand and a lot of thinking :) Maybe some of you guys should think twice before you hand launch your new X8 or similar...
Now i'm considering several options:
1. Build a catapult
2. Hand launch engine off and throttle up after the wing has left my hand
3. Build a device where i can take off in a 30 deg. angle just by using the propeller power itself?
4. Any other ideas??
Item # 1AJ44
Cut Resistant GlovesUncoated Coating Material, Kevlar(r) Lining, Cut Resistant Yes, Abrasion Resistant Yes, Puncture Resistant No, 2 ANSI/ISEA Cut Level
They only cost a few dollars
Thanks for posting this, safety reminders are always good. I hope you heal quickly.
I don't have the RPM but i had 100% throttle and use a 4s Lipo battery on a 650kv engine
Thanks! I think the RPM of the motor is needed as well. Really nasty cuts :-/
38mm between the cuts and 14x9.5 inch propeller. Be my guest :-)
In theory, i think you should be able to calculate the launch speed if you measure the distance between the cuts :-)
@Jared: I will think about the winf launch
@Jason: I saw others fly with a much larger prop than myself so i wanted to try. I had one test before my hand injury and it looks very good with that prop size. Longer flying time on same mAh.
@Dwgsparky: I would like to see pictures/videos of your catapult and consider buying one.
Why a bigger prop in the 1st place?
Wing launches allow you to throw much harder and they also allow you do do spin launches where you spin on the spot for extra speed and launch, mainly for large models that have a high stall.
1
2
3
4
5
of 5 Next
