Posted by Nick Goodey on February 24, 2013 at 3:30am
200 mW TX on a 120mAh Lipo runs about 30 mins. Total weight with Lipoly 6.2 Grams, only 3.6 Grams with a 5V regulator so it runs of the main battery. The image is not great on a single Lipo cell. I will try it connected to a spare port on the RX see what the signal is like.
With this camera you need to block out the light from the back of this camera of the PCB tracks show in the video feed. It needs a light enclosure for the whole assembly, nice and thin so it won't drag too much on top of a wing of where ever.The wires on the camera are a little fragile so I potted them in hot glue so they don't fatigue.
This 420TVL Micro Camera with LED is perfect for FPV applications. The included LED ring provides visibility in dark conditions. This unit is a great low cost option for your FPV model.
This module is a 2.4Ghz band micro-power radio communications receiver, generally used to transfer audio and / or video in Arduino applications.
Designed around a low-power integrated VCO, PLL and a broadband FM video demodulator using a FM sound carrier frequency. This module complies with CE - FCC leakage requirements.
The applications for this module are vast and only limited by your imagination. This unit can also be used as a great low cost 2.4ghz Micro FPV solution.
Dear Nick Goodey.. Hope you are still around. I am Dom. New to forums & drones. I am, sadly, not a micro electronics person. Recently I got a parrot mambo. I hugely want to make a tiny wifi fpv camera setup for it. I think from your pictures that you could assist. Sadly I do not understand the terms used or the concepts explored. I really need to have a chat with you, to understand a bit, to discuss if what I intend is possible & basically to get a complete shopping list from you of what I need. Apologies for asking for this but I get the feeling that this is right at the bottom of your ability spectrum & so no bother. If you cannot assist could you please put me in touch with someone who could? I am bursting with design ideas & desperate to tinker & create. Please help.
Hi, I'm a newbie here. May I know the connection of the fpv transmitter and receiver module?
Seems Ok at 100 meters I would estimate (not measured) in an open space its 200mW so quite powerfull and Xbee is up to 100mW
What is the range?
