Take a look at the mod I made for the mega to incorporate a sonar range finder.
Code in zip above
The sonar interfaces to the relay pin 47.easy to do
http://www.robot-electronics.co.uk/acatalog/Ultrasonic_Rangers.html
Agreed, it's about $25 elsewhere. Maxbotix also have some smack talk about the SRF02 here:
http://www.maxbotix.com/Performance_Data.html?gclid=CIKj2rz74aMCFQI...
Their comparable sensor (EZ04) is about $30.
do you have method or link to- of integrating the" "polaroid" sonar"?
Leon.
The advantage of the ping unit is it can measure down to 1 or 2 cm and out to 11 feet or so.
Earl
Yes, that is the sensor I used.
Earl
Earl
http://www.robot-electronics.co.uk/htm/srf02tech.htm
It also requires pulse width measurement, whilst the SRF02 will give you actual distance, calibrated, over I2C.
do you use this one? http://itp.nyu.edu/physcomp/sensors/Reports/ParallaxUltrasonicDista...
Greetings,
Florian
Might be a cleaner option instead of using the pin for the relay.
chris.
You do see the ping library file and put it in your arduino library ?
Earl
1
2
3
of 3 Next
