Sony camera controlled with RC transmitter
proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-GuyfBo2dEGo%2FVFZE4UkC6sI%2FAAAAAAAAAJo%2FbVkSWvEyeKs%2Fs1600%2FIMG_1774.JPG&container=blogger&gadget=a&rewriteMime=image%2F*&width=350for this demo I used 3.3v as power source for the receiver but in real life it will probably be a 5v power source so you'll need to figure a way how to do it (resistors, level converter...)
so let's start
what you need:
sony block camera (visca)
arduino (3.3v)
rc transmitter
rc receiver
monitor with av
fcb-ex11d
arduino mini 3.3v
proxy?url=http%3A%2F%2F3.bp.blogspot.com%2F-oWvvP1604Zk%2FVFZPMQ2lr1I%2FAAAAAAAAAJ4%2FlzkHQYpbMEE%2Fs1600%2FIMG_1783.JPG&container=blogger&gadget=a&rewriteMime=image%2F*
rc transmitter - spektrum dx6i
proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-RLpI2rdz3fo%2FVFZPkTL4nAI%2FAAAAAAAAAKA%2FRX-0ULUHuH4%2Fs1600%2FIMG_1772.JPG&container=blogger&gadget=a&rewriteMime=image%2F*
ar6200
proxy?url=http%3A%2F%2F1.bp.blogspot.com%2F-r-CTWmjzRZM%2FVFZPmyFs15I%2FAAAAAAAAAKI%2FewwSnEBLiXU%2Fs1600%2FIMG_1777.JPG&container=blogger&gadget=a&rewriteMime=image%2F*
then you'll need to hook up the wires as so
camera rx to arduino tx
camera tx to arduino rx
camera gnd to arduino gnd
arduino digital pin 3 to reciever elev channel
proxy?url=http%3A%2F%2F3.bp.blogspot.com%2F-kgRUB4V93yM%2FVFZPr0LaL-I%2FAAAAAAAAAKQ%2Ffh_DBgBXPAo%2Fs1600%2FIMG_1779.JPG&container=blogger&gadget=a&rewriteMime=image%2F*
then you left with video and power
power specs says 9v plus or minus 3v
and video is ntsc so any suitable
monitor will do the job
and of course the code :)
/* build and tested using
sony camera block fcb-ex11d and
rc transmitter spektrum dx6i with
ar6200 reciever and connected to the elev channel */
byte address_set[4]= {0x88, 0x30, 0x01, 0xFF};
byte if_clear[5]= {0x88, 0x01, 0x00, 0x01, 0xFF};
byte command_cancel[3]= {0x81,0x21,0xFF};
byte zoom_teleVar[6]= {0x81, 0x01, 0x04, 0x07, 0x23, 0xFF}; //zoom in 81 01 04 07 2p FF - p=0 (low) to 7 (high)
byte zoom_wideVar[6]= {0x81, 0x01, 0x04, 0x07, 0x33, 0xFF}; //zoom out 81 01 04 07 3p FF - p=0 (low) to 7 (high)
byte zoom_stop[6]= {0x81, 0x01, 0x04, 0x07, 0x00, 0xFF}; //stop zoom
byte auto_focus[6]= {0x81, 0x01, 0x04, 0x38, 0x02, 0xFF}; //auto focus
const int thisdelay= 250; //time between sets
const int zoom_out=3; //Zoom
void setup() {
pinMode(zoom_in, INPUT);
pinMode(zoom_out, INPUT);
// initialize both serial ports:
Serial.begin(9600);
//send Address set
for (int i=0; i<4; i++){
Serial.write(address_set[i]);
delay(thisdelay);
//send IF_clear set
for (int i=0; i<5; i++){
Serial.write(if_clear[i]);
delay(thisdelay);
//zoom in
void loop() {
int zoom_inState=pulseIn(3, HIGH, 25000);
if(zoom_inState>1550 )
delay(thisdelay);
//Send zoom tele set
for (int i=0; i<6; i++){
Serial.write(zoom_teleVar[i]);
//zoom out
int zoom_outState=pulseIn(3, HIGH, 25000);
if(zoom_outState < 1400 )
delay(thisdelay);
Serial.write(zoom_wideVar[i]);
//zoom stop
if(zoom_outState < 1500 && zoom_inState > 1400 ){
//send auto focus cmd
Serial.write(auto_focus[i]);
//send zoom stop
Serial.write(zoom_stop[i]);
void sendcommand_cancel(){
for (int i=0; i<3; i++){
Serial.write(command_cancel[i]);
next thing will be to import it to attiny85
will release the code later tonight
**got really cool board that im using called attami (google it :) )
i was told that it will cost 1euro (not assembled)
and will be available at c31c (chaos communication congress #31)
3689624257?profile=original
code for attiny85 or attami :)
#include <SoftwareSerial.h>
#define zoom PB0 // zoom
#define rxPin PB1 // rx
#define txPin PB2 // tx
SoftwareSerial mySerial(rxPin, txPin);
void setup() {
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
pinMode(zoom, INPUT);
mySerial.begin(9600);
//send Address set
mySerial.write(address_set[i]);
delay(thisdelay);
//send IF_clear set
mySerial.write(if_clear[i]);
delay(thisdelay);
//zoom in
void loop() {
int zoom_inState=pulseIn(zoom, HIGH, 25000);
delay(thisdelay);
mySerial.write(zoom_teleVar[i]);
//zoom out
int zoom_outState=pulseIn(zoom, HIGH, 25000);
delay(thisdelay);
mySerial.write(zoom_wideVar[i]);
//zoom stop
mySerial.write(auto_focus[i]);
//send zoom stop
mySerial.write(zoom_stop[i]);
mySerial.write(command_cancel[i]);
  • i dont think that there is a visca cmd to do what you ask
    but you can program it for a specific ppm
    featured on hackaday
    3701870084?profile=original
  • Excellent work and documentation! A very useful project for the community.
    I was wondering if there is a way to control the camera zoom level i.e. x2, x3…etc, by sending absolute PWM values for each zoom level. That would certainly be a huge added value.
  • Good work elad. I too was working on a similar unit (FCB-EX980SP) up to eighteen months ago. Other things took a greater priority as they do! Your post has prompted me to revisit this. Although I have not yet attached it, I also purchased a stabilization output module so I can use as much of the superb zoom these cameras have as possible!
  • Excellent work !
  • I have been looking for an implementation like this for some time now.  I have a Sony FCB-EX1010 and by using the support PDF, I should not have much difficulty making it work with my setup.  I was also thinking about a way to wrap some of these commands into a MAVlink stream and have access to some of the other features of my camera such as switching between NIR and full color, similar to the features I'm used to with the RQ-7b system I operate.
    Thank you very much for this!!
  • many thanks
    those kind of comments makes me continue building things and how to replicate them
    also the visca pdf i used to make the code can be found  here
    also forgot to mention it but i used a 3.3v to save the use of another component
    if i used a 5v version then i had to use a 3.3v level converter or couple of resistor to talk with the camera
  • I used one of these cams myself and they're great for surveillance applications on a multirotor/heli at a price of $300 or so plus the arduino and other electronics. The zoom really needn't (shouldn't?) be more than 6x, because the vibs and movements will interfere. I have the feeling your sketch here is going to be referenced by other builders in the future. Great work!
