3689740907?profile=original
Make your Companion Computer more stable, not suddenly reset by fluctuating power supply in fly time, reduce noise by the devices like ESC, motor, servo…
https://product.xb-uav.com/stable-power-module
Stable Power Module
3689740971?profile=original
Stable Power Module is professionally designed with power IC 5V-5A to provide stable power for Companion computer as well as peripheral devices. It also has a built-in Serial port for connecting Companion computer and flight control. All connector in Stable Power Module is Dronecode standard (JST GH and Molex Clik-Mate)
3689740898?profile=original
Easy Connect
  Technical detail
Weight:  21gram
Dimensions:  60 x 35 x 15 mm
Power Input:  7 to 36V power input (CLIK MATE 2.00mm)
Power Out:
  5V/5A for
  • Rasp Pi (Jump 2.54mm)
  • Cooling fan, Peripherals (CLIK MATE 2.00mm)
Features:
  • Serial port (JST-GH)
  • Reverse voltage protection
  • Resist fluctuated, noise of electric power
  • Green Led Indicator Power
Compatible:
  • Compatible with all companion computer which have Rasp Pi pinout (2x20 2.54mm)
  • All Raspberry Pi models
  • I haven't tried it yet, but I think it's possible. NVIDIA Jetson Nano J41 Header Pinout is similar to Rasp Pi Pinout(5V - Ground (supply power- Pin 2,4,6) and RX-TX (UART-Pin 8,10)). My PCB is 5A-5V, it's strong and stable for Jetson Nano.
  • Hi,
    Nice board, did you try to power a jetson nano ?
    Matt
