Made a successful flight 21 June with the Easy Star and ardupilot 2.6
The flight was autonomous from the start of the video to 20:43:06 (time on video).
For this flight I forgot to install the gps tracker, so no nice flight path graphics:(
Header file used for this flight:AP_2_6_header.h (details on airframe are below)
Here is the video of the flight showing the Dutch polders.
Enjoy
Part 1
Part 2
This was the mission plan.
The airframe
Details:
Ardupilot 2.6 with shield v2 (mounted in the first opening under the wing)
XY and Z IR sensors
Ublox GPS (Mounted on the tailboom on top of the xy sensor)
900mHz xbee for telemetry
Turnigy B2835-2700 Motor with 30A ESC (mounted in the second opening)
Turnigy camera from Hobby King
You are both right it is best to have the antenna's in a vertical position.
The Xbee antenna can bend 90 degrees up, I think the Ublox performance is sufficient in the horizontal position especially when it's flying. And it was easier to mount this way.
Check out http://en.wikipedia.org/wiki/Dipole_antenna and look for the drawing of the doughnut...
Congrats well done!
Mike.
Could you publish details of your setup, KML or Telemetry if you have any, and your header file?
Jason
