3689516498?profile=original
I have a thought to use cellular technology to pipe video and data over a UDP connection.  This is nothing, however, I haven't seen a lot of support for the usage of 4G/LTE which allows up to 100mbps speeds.  Has anyone ever read up on this pico board?  I'ts available from min-box.com.  The same place I received my mini-PC for my GCS.
I had this idea about hosting a UDP server on board the aircraft with this pico board.  Then routing all traffic through a VPN tunnel where it will be connected to the GCS via internet/VPN tunneling.
The APM will connect to the board via serial I/O.  The tricky part (for me) will be routing that serial traffic over a UDP connection.  Any idea a simple(r) way to do this with Linux instead of any software-based routing procedures?  I very familiar with Linux, just haven't done any network routing inside a client-only environment.
Any thoughts or concerns are more than welcome!
  • Yes John, the Pi has it's weaknesses. But there are other small Linux devices with Quad 1.7Ghz and lot of power compared to the Pi.
  • Tommy I am looking forward to a blog writeup on your setup. I think I might go a very similar fashion.
  • @John: It's not complicated at all. My 3g router is smaller and lighter than an Android and my serial2wifi PCB is very small and light. I also want to use my GoPro Hero2 as cam and i cannot see how i can connect this to an Android for streaming. My solution is simple and stable :-)
  • 3G is what I meant...you guys got the idea.
  • Using 4G should increase data throughput better than 4G.  Experimenting with FaceTime, I noticed the latency is FAR less than it used to be.  I will give this a shot, while staying on the Verizon network, and report back my findings.  Thank you for all the info gents!
  • can you actually fly fpv with a 300ms lag? that seems pretty dangerous
  • For a long time i have been using a Raspberry Pi with a USB video capture device (Terratec Grabby) connected with my Hero2 to transcode the SD video into 352x288 10fps at 500kbit and it works very good over 3g network with a latency of around 300ms. I have a wifi adapter in my Raspberry Pi and connect this to a 3g wifi router onboard. I also connect to APM2.5 via the same link. I'm working on a blogpost to describe mye setup :-)
    Tommy
  • Bryan,
    Interesting stuff about the DM368. I have been looking at the Z3 module you mentioned as well. Unfortunately its a little expensive for me to buy, at the moment..so will have so save some more. Can you tell me if you built a daughter board to interface the module to a camera? What camera are you using and what's the interface between the camera and the Z3 module?
    Also, an odd question..how easy or difficult is it to work with video encoding/decoding with the DM368? :)
    Saad
  • BTW: I'm already running my aircraft via 3g. Both video and telemetry.
