Tersus UAV PPK Solution with Base Station
Tersus UAV PPK solution includes BX316R PPK Receiver, AX3705 Helix Antenna and Tersus GeoPix Software. BX316R PPK Receiver supports multi-constellations and dual-frequencies. It has in-built 4G memory for GNSS observation data recoding. Very small and light AX3705 Helix Antenna is designed for UAV applications.
Tersus GeoPix integrates the functions of GNSS observation post processing, Event Mark interpolation and geotagging in EXIF. By clicking one button after input all necessary data, the software will provide the result directly as input for image processing software.
We provide David Base/Rover Kit Network Mode as default kit as Base Station working with UAV PPK Solution. It can not only work as Base Station to record GNSS raw data for post processing, but also as an easy-to-use Rover receiver to measure Ground Control Points for photogrammetry.
