Thalon quad W/ naza-M flight controller
3689549597?profile=original
This is the quad that a friend and i are working now.
Its a Turnigy Thalon quad frame, with some mods. It has a pvc tubing landing gear.
Motors are NTM 3530 prop
drive.
FC: Naza-M with GPS
ESC HK 40 A opto esc.
It is equiped with the gopro black edition.
battery its 4s 5.8 Ah, zippy compact
I am getting 9 minutes of flight time.
The AUW its 2 kg
  • A little bit, yes. But with the accesories tha came with the Gpro we already fix it. In that flight we were setting up the gains of the gyros, so you can see that the camera is pointing towards the sky and not to the ground as it should be.
  • Here are some photos in flight3692836635?profile=original
  • I stuck it in the arm in first place, and the i attatched the arm in the central plate.
  • MR60
    How did you attach your PVC landing gear on the plates ?
  • The central plate is all Turnigy Thalon. The kv for the motors is 1100 with 8x4.5 props.
    We are planning to do aerial videos with the gopro, and some aerial photography with a canon SX260.
    I tested the same setup with a 10x4.5 props, and they are way powered, at the point that when i cut the hole throttle stick the quad is still on the air. It was dangerous.
