Skywalker is now in a new version made of EPO foam. Much stronger foam.
Length: 1180mm
Wingspan: 1680mm
Wing Area¡G35.5dm2
Wing Loading¡G36.6
Recommendation
4 x 9g Servo
3S1P 11.1V 2200mAH-5000mAH
Motor: 2215-1200KV or 2815-900KV
Propeller: APC-9045E 9060E
I think this platform could be the replacement for the smaller Easystar if it's possible. What do you think?
Skywalker is now in stock! This is not the EPS foam, this is the new EPO version - much stronger foam.
See more on this Skywalker FPV UAV platform.
Se more here on the Skywalker EPO platform
http://www.fpvhobby.com/6-fpv-airplane
It won't be an easy quick job. But it is possible.
I'm working on making a Glassfiber mold for the little foamy UAV. When the mold is done then it's an easy job to make more. But it would be wrong to sell is. It's not an open source platform :-)
I did a little calc on the Shipping on the Easywhale. The weight will be 17 kg because of the size. So EMS is a no go.
Big numbers and shipping by sea is the only way this model see the sky in numbers.
1
2
3
of 3 Next
