The Quad Rotor Observer (QRO) v6 with a GoPro HD Wide
Here a video of the new Quad Rotor Observer (QRO) v6 with a GoProHD Wide on board.
Flight controller hardware:
KKmulticontroller "BlueBoard" from Minsoo Kim's
( http://kkmulticopter.kr ) and based on the board of Rolf R Bakke
Flight controller firmware:
XXcontroller_KR_v1_4a based on assembly code by Rolf R Bakke converted by Mike Barton modified by Minsoo Kim and Jean-Louis Naudin
- 4 brushless motors 750 Kv RCtimer 2830-14
- 4 ESC 30A
- Lipo battery 3S (11.1V) 2550 mAh
- receiver Corona CR6D 2.4 Ghz
Video Camera:
GoPro HD Wide
More infos at:
http://diydrones.com/?profile/?JeanLouisNaudin
  • This is great work! Jean-Louis, I've been keeping up with your online contributions online (physics) it's inspiring to see your work on quads as well
    -Aurelio
    Here the diagram of the KKmulticontroller board (Jakub version) successfully tested on my QRO v6:
    3692158343?profile=original
    3692158987?profile=original
    The original ATMEGA 48 on the Jakub board must be replaced by an ATMEGA 168-20PU to load the XXcontroller_KR_1_4a firmware.
    Regards, Jean-Louis
    Below some various KKmulticontrollers which also works very well on the QRO v6 with the same firmware XXcontroller_KR_1_4a :
    • This is the KKmulticontroller from Jakub which uses three boards from HK401 Gyros, the original Atmega 48 have been replaced by an Atmega 168 and the firmware XXcontroller_KR_1_4a have been installed:
    3692158759?profile=original
    • This is my home made KKmulticontroller v7 with an Atmega 168. I use three piezo gyro NEC Tokin ENC-03 ( piezos board from HK401 gyros will work too).
    3692158687?profile=original
    3692146804?profile=original
    3692146906?profile=original
    • Of course, the KKmulticontroller from Minsoo Kim works well...
    Regards, Jean-Louis
    Here below a new winter flight mission with my QRO v6:
    Winter flight with the QRO v6 and a GoPro HD Wide on board
    Regards, Jean-Louis
    Here a winter flight mission with my Quad Rotor Observer (QRO) v6 with a GoPro HD Wide on board.
    QRO v6 winter flight mission with a GoPro HD Wide on board
    Regards, Jean-Louis
    High Speed and High Turn flight tests:
    Here a new HD video of the Quad Rotor Observer (QRO) v6 with a GoProHD Wide on board.
    Regards, Jean-Louis
    Here a new flight mission video with my QRO v6 that I have done on January 23, 2011 afternoon:
    Flight mission with a GoPro HD on the Quad Rotor Observer (QRO) v6
    Regards, Jean-Louis
    Hello Chris Cashmore,
    Thanks for your comments, here the QRO v6 specs loaded with the GoPro HD camera on board:
    Take Off weight: 1062 g (Lipo 3S 2650mAh Turnigy rated for 40-50C with GoPro HD camera)
    The Avg Power required to hover at 2 m AGL : 180 Watts
    This gives a Power/Weight ratio of 168 W/Kg about 4.5 A peak / motor
    Flight time about 9 min
    I have previously used Lipo 3S EVO25 2550 mAh rated for 25C, today, I prefer strongly to use Lipo 3S 2650mAh Turnigy rated for 40-50C.
    Below the tests results with the Lipo EVO 25:
    3692156977?profile=original
    Regards, Jean-Louis
  • Very nice indeed!
    What kind of total flight time do you get with this setup (with an average speed, not full throttle)? And... What is the total weight of the quad with camera?
    Thanks.. Keep up the good work.
  • Nice video!! I have those motors and ESC, really cheap for the permormance!!!! The best decision I have made :D!
    Im designing a CF frame that will look like the MD4 on the arms and motors mounts. The advantage of CF tube on the arms is drag reduction!  I wiil be posting my design ASAFinished!  If someone knows where I can get a foam with the golfball texture ( Dimples ) please let me know! ;) Im planning to use it on the prop coverage area of the arms to increase laminar flow.
    Jean Louis, I like a lot your setup! High performance simple setup!  keep it up!
