Today, my TrIMUpter v1.0 has successfully done its first outdoor flight. This is a VTOL Tricopter fully stabilized by the ArduIMU+ V2 flat and (with my firmware TriStab v1.0). No external gyro here, only the ArduIMU on board... The TrIMUpter is able to flight outdoor and indoor.
More photos at: http://diydrones.com/photo/albums/trimupter-a-vtol-tricopter
Stay tuned on: http://diydrones.com/profile/JeanLouisNaudin
  • Bonsoir Jean-Louis, félicitation pour la réalisation du TrIMUpter v1.0:
    Je vous ai envoyé un message ce matin sur votre email diydrone, mais je n’ai pas eu de réponse.
    Est-il possible d’avoir un plan avec des cotes pour la réalisation ?
    Dans le futur, est ce que le TrIMUpter v1.0 pourra voler en auto via un GPS ?
    DODY
    Below the main parts list of my TrIMUpter v1.0:
    - ArduIMU+ V2 flat (a 6DOF IMU)
    - HMC 5843 triple axis magnetometer (Sparkfun)
    - 3 brushless motors Hextronik 1300 Kv, HXM2730-1300
    - 3 ESC Hobbyking SS Series 8-10A
    - 1 servo Corona 919 MG 1.7kg/ 12.5g/ 0.06sec
    - 1 Lipo battery 3S1P 11.1V 1500mAh
    - 3 propellers CCW GWS EP0843
    Below some detailled photos which shows the connections to the ArduIMU:
    Hello Yves, the magnetometer is required to compensate the Yaw drift in the IMU, without a magnetometer you will observe that the yaw drift slowly during the hovering phase. With a common plane the yaw drift can be compensated with a GPS due to the motion of the plane. With a VTOL type craft which hover it is not possible to use a GPS because the heading can't be computed with accuracy. In my ADAV/VTOL you will notice that I have used a heading Gyro commonly used for helicopter (GY401 or HK401), this device is able to lock the heading...
    My firmware is currently in alpha stage, so I need to cleanup the code and conduct more deep tests in flight, as soon as it will be ready for beta, I shall soon release on the web of course... If there are some TrIMUpter beta tester, here, they are welcome...
    Regards, Jean-Louis
  • Hello,fine, I like your tricopter, simple, cheap. Just a question, why are you using the magnetometer? and the firmware TriStab is new?
  • Would you be able to post your firmware as well? There are others interested in using ArduIMU for tricopters, not just quads.
  • Congratulations on your work. The fall foliage in the above picture is beautiful- Maybe you can record a bird's eye video from the TrIMUpter as you fly around the trees!
    The TrIMUpter, a VTOL Tricopter with the ArduIMU+ V2 from Jean-Louis Naudin on Vimeo.
    Here a video of the 1st flight of the TrIMUpter...
