Tweaked standard 3DR quad
3689562994?profile=original
overall top view
3689562945?profile=original
gopro mount instead of battery holder
3689563213?profile=original
arms are sealed with (color matched) tape, one motor mount hole is used for positional lights
3689563162?profile=original
escs, homemade pdb and power module are hidden between center plates. rear standoffs together with power, light and pwm cables are covered with heatshrink tube .
3689563129?profile=original
top view, on the left side is the light controller
3689563179?profile=original
all electronics are affixed to a plate, damped and covered with a cd case
3689563147?profile=original
battery power connector fixed to arm with doublesided tape and ziptie
  • try this QR brain 4 in one ESC on 3DR quad. it fits very well between the two plates. it makes a great difference which i do not know how. the quad does not moves laterally even in manual mode3692901136?profile=original
  • I'm like cd bulk box head =)
    I like the propellers.  They look similar to the Graupner props that Dave C put on his copter that won last year's AVC.  DaveC's was also at it's heart a 3dr quad but seriously pumped up with high kv Tiger motors, those props, 4S battery and a couple of other bits.
  • The telemetry antenna is one thing i really want to do differently, on a similair design i couldnt make the escs significantly hot, so im assuming this wil be ok. The battery goes above the escs and under the electronics.
  • MR60
    Clean build but I see at least three potential weaknesses:
    -where do you put the battery?
    -your telemetry antenna is horizontal and burried in cables and electronics which is is optimal to say the least
    -your ESC s are burried internally and on top of each other so the heat cannot dissipate
  • Looks very clean and should work fine.
    APM height offset doesn't really make much difference accel or gyro wise, but from a wind / gust or relative wind standpoint it would be better to have the enclosure lower and a compass-GPS on a mast.
  • it was lower, but due to magnetic interference i had to put it higher. now the motormot returns 4%. i flew it shortly and it looked ok. any experience with apm that high?
  • T3
    Very clean design.
