The UAV Challenge Medical Express rules have been released.
The Mission for 2016:
"Outback Joe is at his property in remote Queensland, Australia and has been feeling unwell. He has had a remote consultation with his doctor using video conferencing, and his doctor has requested some blood tests be done as soon as possible. Joe is well prepared, has a home sample taking kit, and has taken his blood sample. The challenge is now to get the blood sample to the lab. Joe’s property is very remote and to make matters worse, it has been cut off by floodwaters.
Teams are invited to attempt to retrieve a blood sample from the remote Outback Joe and return it to base where medical staff will be waiting to analyse it. Teams must deploy unmanned aircraft to Joe’s location, and then return a sample bottle from him utilising a remote landing and takeoff site close to him. They must complete all of this within one hour."
Documentation can be found here:
Rules PDF here: https://docs.google.com/file/d/0B5JgqjkRDqw8dTllN085ZTJyNjQ/edit
Site: http://uavchallenge.org/medical-express/
Challenge FAQ: http://uavchallenge.org/medical-express/medical-express-faq/
Brief overview of the 2016 OBC rules:
- Two aircraft are allowed that can detach/reattach to eachother > one as retrieval aircraft and one for support > both can be airborne at the same time
- Range required +40km but no more than 60km through "bent" geofenced transit corridor - waypoints will likely backtrack to get the total distance, but will be at least 250m apart. (see FAQ)
- Flight must not take longer than one hour so the airframe must be able to achieve roughly 90-100kmh average, as well as be VTOL or STOL (!)
- The RF Link range required is approximately 10km (3-4G Mobile and Satellite comms allowed - safety case req. for landing zone etc)
- 1500ft AGL altitude restriction
- 25knot average wind over 10 minutes will cancel the event (which is higher than last time)
- Joe GPS coordinates that are provided are within 100m of Joe. One must locate him and land no closer than 30m, but no further away from Joe than 80m - distance away is scored at 2 points per meter - Joe has lost his colorful shirt but kept his jean pants on - phew!
- payload to be picked up is 20x100mm and no more than 100g and must be returned intact back to base.
- aircraft must remain motionless for 1 minute after landing near Joe before Joe will approach to place payload - Takeoff Arm switch is required by Joe at pickup location with one minute takeoff delay after activation
- Biggest points are for delivering intact sample back to base
- Only the top 20 ranking teams through D1-D3 will get to go (based on paperwork, flight logs and videos) - That will be tough
- Might not be at Kingaroy this time...
No specifics are given to the makeup of the Joe takeoff landing site or base site, apart from that it will "impede low glideslope landings". So this could allow something like a Skywalker X8 with a quadcopter strapped underneath to launch and fly to location, identify and locate Joe exactly, then detach the quad for payload retrieval, while the X8 stays above the landing zone as RF relay until quad is released to takeoff, then both can head back with the X8 arriving first and possibly landing with a parachute and then the quad with payload some minutes later. A single VTOL might be nice but you'd have to land/takeoff blind without RF link. Helicopters welcome.
Shouldn't be too hard.... I think I have the gear for that here already. Time to dig out old Tinker Bell and send her back to get Joe! ;-)
JB,
thanks a lot! I read the text again and think you are right. They are talking about the "total length of the flight path", which should mean the bidirectional path.
By saying "making the base higher" do you mean putting the antennas on a very high mast? That's a good idea and the question would be how high a mast they would allow and how high a mast you can put up within the 15 minutes of setup time. ;)
Happy you like ObliX! Unfortunately we are still in the design phase and will probably not be ready in time for the Medical Express Competition deadlines. But we would definitely like to take part in one of the next Medical Express Competitions coming. However, I am wondering how "landing" is defined and if anchoring an airship to the ground and switching off the motors would count as "landing" or not.
AsterX could be the name of the quadcopter ObliX could be carrying to the remote landing site. ;)
We should really open a discussion thread somewhere.
Another concept that might work, and be very simple, would be a quadcopter with a pusher prop. I've seen these played with before and it works. Probably capable of 100 km/h. (just don't know for how long)
Also, so far, our concept has been that we would need a "flying repeater" to orbit the landing zone. But what about a completely independent flying repeater, that would hover over the home base, or possibly move to the mid point? This could be an efficient quadcopter type system. But would it work from a radio-science perspective, if the repeater was not directly overhead the landing zone?
Or, could you have the large VTOL lander, drop a Skyfun at altitude that would orbit and be the flying repeater, which then would return to base and do a rough landing? Almost a disposable aircraft. Not quite, but they were landing them in a really small area at AVC.
I would like to see somebody make a really good STOL airplane. Huge flaps, leading edge slats, serious landing gear with shock absorbers. If you look at the full-scale world, airplanes like this are used in the bush, rather than helicopters. They aren't as efficient as a glider, but they still have more range and lower operating cost than helicopters.
Evolution improves the breed, so let's look at every possibility. I don't see why you couldn't land an airplane in about 20m and like a 2:1 glideslope? %diydrones.com
Sam, Daniel
I agree that 1.2.3 is ambiguous. But the Deliverable 3 chapters in 5.3.3 outline the aircraft requirements further, as they need to receive actual flight logs of the aircraft's performance otherwise the team will not be allowed to participate and even come to the event. This was the same in the last OBC 2014. In particular is says logs for more than 20km range and more than 30 minutes endurance are required for each aircraft. Essentially this is the "pre-qualification" round, but you do it home before you come.
Also the transit corridor photo in the rules shows something of similar range. According to the angle of the paths shown I'd say about 12-13km one way if the distance between base and landing site is 10km...if the drawing is accurate. There's no reason for them not to tell us the requirements and surprise us with more range. But hey who knows? Last time they sprung us with the fact that all the gliders would be operating out of the airport while we flew, and that the best 4-5hours for imaging, out of the middle of the day could possibly be cancelled. It worked out in the end though in that we flew at the same time as the gliders at the airport. We had to wait some 20minutes whilst a bunch of them launched, but it went really well for that it was the first time anyone had done UAV and GA from an open airport at the same time in Australia. Made us fell like we belonged somehow! ;-)
BTW Daniel I like your ObliX. Are you panning on making on making a smaller Asterix? ;-) I think something like that might be the go for this competition as the support aircraft. Wind will be a factor for an airship though, it's always got some wind in Australia!
I agree that 1.2.3 could be interpreted as a 20 to 30 km trip each way (total of 40 to 60 km). It's not really clear in the wording...
Daniel
The flight corridor is only 10-15km long one way. So up to 30km return trip. Deliverable 3 requires a flight log of 30 minute or minimum of 20km to be presented. So you can expect to do either half the speed or take half the time you calculated.
Head wind will need to be overcome but a tail wind will help. It's unlikely to be that windy, and 25 knots is the cutoff for the event not the expected wind. A smaller quad could manage a single flight back, but there's some issues with having to present a log of it's performance beforehand, which essentially means it needs to be tested and logged the same as the support aircraft. Which is silly IMHO as the secondary aircraft must have essentially the same range, so two aircraft only really help for maintaining a comms link, as they both have to be capable of flying the distance anyway.
I'm thinking of a way to overcome the comms link problem, other than just 4G, but it's likely some more information from the organizers will be required to make sure it's allowed. Like Gary said: Making the base higher might work. ;-)
The regulations in chapter 1.2.3 say:
"The total length of the flight path through the Transit Corridor will be less than 30km but greater than 20km."
Do I understand it correctly that one way through the Transit Corridor is >20 km? So the total path to fly would be >2*20km?
If e.g. the real length of the Transit Corridor would be 25 km, that would mean the total bidirectional path length to travel would be 50 km, right?
If I further assume that 12 minutes would be needed to find Joe, land, wait for loading the blood sample and waiting again for takeoff, then 48 minutes would be left for traveling 50 km. That would mean an average velocity of 62.5 km/h.
If I assume the worst wind scenario of 25 knots (= 46.3 km/h) the average speed relative to the wind might have to be even higher than 62.5 km/h. Maybe rather 70 or 80 km/h?
If the above considerations are correct, then I think it might be quite hard for a little quadcopter to fly back with the blood sample for 25 km at an average speed of >62.5 km/h.
Where am I wrong?
Hey Gary
Do you know something I don't? Will the base be on higher ground? ;-)
Even so I don't think the RF fresnal on 915mMhz, plus the terrain and earth curvature well get you enough range at 10km apart, even with a decent mast on base. The retrieval aircraft would only be some 30-50cm above ground once landed.
The rules say that manual flight termination must be available to the organizers at all times. This means a comms link that, at a minimum, has been tested at that range and conditions. Unlike previously however there seems to be no requirement to terminate flight on loss of comms for any period, which means there is some "flexibility" in the requirements somehow. There are some uncertainties in the rules, and I'm sure these will be clarified in v1.2.
From what I can tell so far, and after doing some considered thinking for each rule presented, I think the biggest hurdle is formulating a strategy on which aircraft(s) to use. Technically, even control and recognition wise there doesn't seem to be to many difficult hurdles. The requirement to operate in confined landing/takeoff zones seem to be the biggest hurdle, yet even there a conventional helicopter would likely be the best contender, provided the comms term. link is upheld as required. Experience might prove otherwise however, but I think this one might just be completed in 2016.
I guess radio won't be an issue if the base is on higher ground than Joe. The first OBC took years to win so this next one can't be made easier!
Hey Naish
There are barely any GSM (2G) networks anymore in Australia. Even then bandwidth for telemetry is a non issue even on GSM. If Joe's using a cellular phone, and not satellite, then there will be 3G reception on the ground at the pickup site. Provided of course the organizers also keep it real from there side and send the SMS from the location as well. I'll be requesting clarification on this but I can't see how they can get out of it apart from saying they're using a sat phone.
There is a lot of infrastructure that wouldn't be included inside of the geofence area. Besides GPS, sat data and even RF comms would go outside as well seeing the transit path isn't straight etc. I don't think they intend the challenge to be to find a comms path that is allowed! The other question is just what bandwidth is required at all. I'd say unless you want FPV, telemetry over RFD900 will suffice. 3/4G will be a good backup.
BTW your English if great! Are you planning on entering?
My english is not perfect, but as is my understanding everything that is needed to accomplish the mission is part of the infrastructure. So mobile network is part of that. Also this is really questionable as this will mean that GPS satellites are part of the infrastructure too. I think you are right, is like last year where they only mean the processing, can't be done offsite. If this is the case, you could install ISM band repeaters along the way.
As for the mobile network coverage, I don't agree. Coverage at altitude is great, but on the ground is a different story . Plus considering the fact that the location still unknown, is a risk starting to work on a phone network based system as you don't know if you will have 3G coverage. Maybe Joe sent you a SMS using GSM only network.
Most viable option looks to be 900mhz ISM modem, and Satellite datalink, or 3G/4G network if you have one aircraft as relay station
3
4
5
6
7
of 7 Next
