UHF RC range extender
3689395278?profile=originalThis $200 radio replaces your RC receiver and connects to your RC transmitter. Using the UHF band and higher power than regular RC gear, it's supposed to extend your range to miles. Mostly intended for FPV flying, but has clear application for UAV use, too.
The manual explains how it works:
Basically, any 4-15 channel radio can work with this system, you just need to find
the PPM signal from the radio.
We can get the PPM signal from the trainer ports for Futaba ( Non-JR ) series
radios. Because the trainer port of JR just output 4-chans PPM signal, so we need to
find the PPM o utput from other places, normally we can get the PPM signal from the
pins of the RF connector
You can get all the definitions of the trainer port for most of the popular radios
here.
For the radios which have removable RF modules, we can get the PPM signal
from the pin of the RF connector
Available now from BevRC.
  • I have ordered and paid for a dragonlink from dragon labs over 2 months ago and have not received anything. does any of the Americans on this site have contact with them as to try and source the goods. It almost seems as if I have been scammed for a couple of dollars.
  • Ok, yes, polititians need topics to divert attention as does the press.
    So the least we can do is to fly with reasonable safety in place. Even if the law and FAA would allow more!
  • The rules of using such kind equipment are depend on the country. Nobody wants to have problems with the law, so I understand you. I just gave an idea about the technical aspect of the issue, not a legal.
  • Duane, thanks for that clarification. I was not talking about commercial, thats definetely another ruleset...
    The use of observers actually is a (human) sense and avoid system. And humans are the only system accapted at the moment (regardles if recreational/commercial, manned/unmaned).
    But then every observer gets a RC transmitter and you don´t need high power...
    My concern is just that the systems in question lead to stunts like the one in NYC... Which I think we agree was not good for the hobby...
  • Duane, in my opinion, going on 27.255 is not enough safe, because it's fixed frequency. Any interference sent on this frequency will hit the plane. Much better to use FHSS (Frequency-hopping spread spectrum), which changes its frequency many times among the band.
    Such systems as Dragon Link, Scherrer UHF use as far as I know 433-444 MHz band. It's much more safety. It's possible to fly 15-20 miles and farther with this systems.
    As for this RC Kit, it looks like Dragon Link, however, the price is twice lower. Nevertheless, who knows, maybe the quality is twice lower too?!
  • Long range ground control can be provided by this system.
    0 feet AGL is an area of operations free from the usual concerns.
    27 and 433Mhz are great in urban environments, reduced reflections, less like a beam of light.
  • Hi Duane,
    interesting, and how do you guarantee "Sense and avoid" ??
  • Hi,
    regarding all the long range systems coming up now I´m wondering if it´s really legal to operate them under HAM license. For germany, I know for sure it´s not (I got my license some years ago and of course checked if it would be useful for FPV video and/or control). In general amateur radio is meant to get in contact with other people and/or do experiments, which both is not the case for these systems. If the laws allow you to use it, you are lucky, of course. But be aware that there can be amateur transmitters on that band running several 100W of power plus antenna gain...
    Anyway I don´t understand why you should need such a system (apart from the price :-) for doing legal UAS/FPV activities, as these have to be performed LOS! Any good 2.4GHz RC-System will give you good results in this range.
    So if you have to use a high power system you eather got interferences (which you should get rid of (better design)) or you want to fly fa away... which you "should" not do.
    So, why is this of so much interest?
    Before anyone sinks too much into comms gear don't forget the WRC meeting coming up next year where the process of UAS frequency allocation continues. The bands allowed for telemetry, control and video worldwide will be defined properly soon.
  • Any CB activity should be AM or SSB (single side band). CB activity has slowed a lot but you might still find some guys running (illegally, of course) a 1 Kilowatt linear amp that "splatters" all over the band if you're close enough. I'm not sure the FCC allows FM on 27 MHz because of the bandwith requirements, but I haven't looked at the regs on that. FM is used in the upper part of the 10 meter ham band from roughly 29 MHz to 30 MHz.
