As promised ("take one for the team") I bought one of the Feiyu FY-3ZT autopilots from Hooks at FPVFlying.com, and it arrived today.
I haven't had a chance to test it (the software only runs on Windows XP right now, and I don't have any XP boxes), but here are the unboxing photos:
The instructions don't look too bad for a Chinese product.
Here are the parts:
--The three boxes in the middle are the (top) IMU, (middle) Remote Adapter and (bottom) Autopilot controller. Only the IMU and the Autopilot go in the plane. The Remote Adapter is for the ground station.
--Hooks also threw in a 433mhz 500 mW long range modem (black modules at left). I have no idea if they're legal in the US!
--There is also an OSD module (FY-OSD); I'm not sure if that's part of the basic kit or Hooks just being generous to me again.
--The GPS module is one of those very small Locosys deals (MC-1513). I'm not a huge Locosys fan, but we'll see how this performs.
--And the thing with the two red Deans plugs looks like a power/current monitor.
--All the rest is all the necessary cables, antennas and mounting bits.
Of course I took the boxes apart. Each one has an AMR7 processor. The IMU has the usual 3-axis accelerometer, a 2-axis gyro and a 1-axis yaw gyro. The controller board has a absolute pressure sensor. All the markings on the chips are obscured with black varnish so I don't know what kind they are.
I've got to fly off to Europe again tomorrow (Paris this time), so I won't get a chance to start testing until next week.
The 'varnish' is a protective coating; it helps protect the components from moisture, etc. Reading part numbers through it is easy, just use some high-intensity lighting and experiment a bit with angles.
The SoC they seem to prefer is the STM32F103RB, which has a CortexM3 core, not an ARM7. Probably not a big deal from the user's perspective, but actually a much higher-performance device than the opening comments might have suggested.
Real test would be a MPX Funjet or Stryker.If it handle that,it can handle (almost) everything.
Actually ArduIMU+ solves the equations onboard with its own atmega328, so it's a true AHRS (thus the "+" in it's name). The IMU shield for APM is just an IMU, as you say, because the processing is done on APM.
Note that I quoted everything from that thread, I'm more curious than anything as some of those comments are just simply bizarre, especially as they attack the hardware ArduPilot have chosen:
"They used such low tech chips for Autopilot???".
This is why I am really looking forward to the flight test of this platform done by Chris, there could be a real opportunity for our projects to learn something and realise we have made a huge mistake with our low tech chips, or possibly there will be another outcome?
