Hobbyking today added this camera to their catalogue and it seems the perfect camera for FPV, an uncased version of the famous RD32 II. Do a search for it on youtube and you will find nothing then good videos. With a AV out for connecting it to the video transmitter or HDMI to connect it to your HDTV this camera is very complete.
Some of the heighlights of this camera are a 120 degree viewing angle and a 5 megapixel 1/2.5" CMOS sensor and a weight of about 89 grams. It accepts micro sd cards from 2 up to 32GB in size. It supports 720P @ 60fps and 1080p @ 30fps.
This video shows exactly what the camera is capable of:
Some of the specifications:
Lens: 5 Mega pixel 1/2.5” CMOS sensor
Photo Resolution:
12M 4000*3000 JPG Approx. 900pcs/4GB
8M 3200*2400 JPG Approx. 1200pcs/4GB
5M 2592*1944 JPG Approx. 1700pcs/4GB
Audio recording: ADPCM WAV format 48Khz ,Mono approx. 22h/4GB
Lens type: F/2.8 f=3mm 120°wide angle
Min. Illumination: 1LUX
Scanning Frequency: Auto, 60Hz, 50Hz
Signal system: NTSC, PAL
Vibration Support: Yes
Battery Capacity: 3.7V/ 1000mAh
For more information, features and specifications, go to Hobbyking: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25656&aff=5361
It can be used for FPV and if I read the manual correctly, you can record video on the micro sd card while watching wireless video (you will need a video transmitter/recevier and viewer for that though).
Can be used for FPV or is playback only?
Here is a manual: http://www.hobbyking.com/hobbyking/store/uploads/675927238X158701X3...
I'd go for the mini 808 #16 cam. It's only $35 and you get 720p video. This is a video of one of them on one of my rockets:
http://youtu.be/HnGAMhotb5k?hd=1
It has a one time offer of $92.99
@Steve It looks pretty tight in there you might be able to solder it but I would be very very careful.
Not interested in FPV, but can anyone enlighten me on how to trigger static (time lapse) photos with this unit?
Couple of questions...
1) Can you remove the lipo and power it from another source (I assume yes)
2) Can you also bypass that USB style connector and just solder a wire for video out?
