Another update on DroidPlanner, now it has nicer HUD. The new app (v0.9.0) is on Google Play.
The new version has the following updates ( v0.9.0 over v0.8.0):
- New HUD
- Removing old Terminal screen
- APM level calibration using a menu button.
- Ability to read/save parameters from/to a .param file.
- Russian language available
- Greek language available
- Latvian language available
- German language available
- Fixed some bugs
- Improvements to the code structure
I would like to thanks everyone that is getting involved with the project, developing, donating and reporting bugs. Here is a list of the developers. I have made a small video of the project history (using gource), here it is (run in 720p to see the people/folders names):
For more information I suggest the DroidPlanner Wiki page. And as always if you want to help consider donating for the project by buying this app, joining the development team, or reporting a issue/bug/improvement on GitHub.
Good work, Hoping to see this work with MP/UDB, cool looking GCS./HUD. Arrow pointing HOME would be gr8(or did I miss it?)
This is amazing app! Arthur, thanks a lot!
@Daniel. As I posted above. HUD and GPS mostly wrorks out of the box. That is all. The Droidplanner platform has great potential but will need development at both ends to (Droidplanner and MatrixPilot) before it is end user ready.
Hi Tom.
Thank very much for taking the time to clarify and pointing me Pete's wiki.
Very impressive and promising developments.
All the best.
Daniel
Hi Daniel,
As of now it does not do much bi-directional stuff with UDB4/MatrixPilot but I believe after a few tweaks it does. Pete has the details on that. I have a new aircraft with a UDB4/AUAV3 and plan to do PID tuning with this App on a tablet over WiFi.
Hi.
That sounds great.
I have both UDB4s (on my Gliders, FPV, etc.) and APM2.5s (quad, FPV plane).
Please confirm or clarify if UDB4 (MatrixPilot) already works with DroidPlanner with full flight plan functionality, that includes "real-time" waypoints creation (with full attributes and options), write, load and save; navigation and setup parameters management, as DroidPlanner and other GCS (AndroPilot, MP, QGCS) works with APM?
If does would you kindly point me to the relevant UDB4 MatrixPilot wiki. Much appreciated.
All the best
Daniel
Done. Can't get the TCP thing to work, DP connects but get no updates on the HUD, not to worry, it's only out of interests sake I wanted to see if I could get it to work.
I just checked and up to yesterday DP has got 1964 active users :).
Tom Pittenger:
TCP was good enough for me to develop, so I stopped there. Any issue that you find just add to the issue traker, I hope to make a somewhat generic Ground Station.
Dave:
Currently you can only modify the parameters directly using the parameters screen. There is a dedicated screen I'm doing, but development has stalled in the last couple of weeks (finishing one of my last semesters in college). If someone want's to keep the work going here is the branch. One good way to help is to just list what parameters should be on this screen, how it should look (keep in mind small devices), any thoughts add them to this issue.
Bob:
There isn't a repositories for the apk's, because google play does a good job of versioning/ updating user phones. One way is to compile from the source. But if you send me an email I can reply with the last version.
Pete Hollands: I love the 33F series, the PPS is a must in any micro (ok, maybe it is somewhat useless in a PIC10F222). Here is a project I did a while ago using a pic33F. I'll like to join you in the development, but I'm already involved with ArduPilot so there is no time. But I would be glad to work together to make DP fully compatible.
Michal:
Like I said, I would like to keep DP generic. Generic in the sense it can fly lot's of boards, and lot's of vehicles ( maybe multiple ones at the same time). That way we all can work together in a single GCS. Maybe it's a dream, but I know I will keep my end working.
titeuf007:
Graham Dyer:
I have designed a board some time ago to simplify this stuff (here is a sample of it working with an early version of DP). Let's break the problem in two:
Since you are a moderator maybe you can help-me on this: How can I get one of those "developer" banners for my diydrones avatar?
Arthur, how can I use Droidplanner on my phone with the 3DR radio connected to a WiFi laptop? (In plain english :) )
