I just bought a wireless camera for my micro heli E-Flight Blade MSR. More on this below....
I took a few weeks to digest everyone's suggestions, and I think I now have a better grasp on my project and where I should take it. For a while I couldn't quite understand why everyone was telling me that I should loose the complexity and stick to simple designs, but then I remembered a term that I supposedly learned in college: "Reynolds number". Doh! Okay okay, I'll keep it simple (stupid). Thanks everyone for knocking some sense into me :-). I really, really appreciate the comments.
Before I try to make my own scratch built MAV, I'm going to experiment with a few easier projects. (BTW everyone, my future MAV is heading more towards a quadcopter...you can say "I told you so")
The above picture is a LTS LTCMW203E1, which is a 2.4 ghz wireless video camera (CMOS). It's arriving tonight, and I hope to tear it down to the board and pop it on my micro heli Blade MSR and hope that it's light enough to fly. I don't expect great results from this, as I'm not really interested in POV (point of view) flying a Blade MSR, but it's a start. I read a lot of concerns about using 2.4ghz transmitters interfering (or receiving interference) from the 2.4ghz system on the MSR, but I've also been told that they work fine. So I guess I'm going to just try it and see what happens. If I had a choice I would have gone w/ 900mhz, but long story short I'm taking a chance and will share my results.
On another note, I am concurrently working on interfacing my transmitter from my RTF blade MSR kit w/ my PC. I've been following the same procedure from http://www.rcgroups.com/forums/showthread.php?t=721024 , and am hoping to be able to read the DSM2 serial tonight. I have been pulling out my hair because for the past few nights I was trying to monitor the serial transmissions without level shifting (I did not realize that microchips speak in 0 - 3.3volt, while my PC RS232 is looking for higher voltage than that, so I need to make a circuit to bump up the voltage in the signal coming from the transmitter). Whoops!! I'll breadboard one tonight and hopefully i should be able to read the serial no problem. Once I can read, writing a program to write the DSM2 serial in LabVIEW shouldn't be too bad, and then I'll use my joystick ( Saitek x45 ) to control my Blade MSR.
Sooooo long story short, once I get the above to work (cross fingers), I'll throw an accelerometer on my Blade MSR w/ a tiny simple transmitter, and experiment with flight stabilization. this is all to help me understand the basics, so I can try to tackle more complex projects like my scratch built MAV.
can Someone help to connect
Saitek Joystick X56 + Scherrer Tx700 Pro + Rx700 LR +PSU
in order to fly a quadcopter ?
And if it is impossible
How to connect the TX700 Pro and the Quanum V52 Ground Control System, please?
https://hobbyking.com/en_us/winbox-ground-control-system-v52.html https://hobbyking.com/en_us/rx700lr-psu-reseller.html
https://hobbyking.com/en_us/tx700-pro-reseller.html
