Using ArduPilot 2.x in the field
Instructions for using ArduPilot 2.x in the field:
ArduPilot 2.1 and above (with Z sensor). This version of the software auto-calibrates the IR sensors. The only thing you need to do at the field is to record the "home" GPS position in EEPROM memory, which will not be erased when you reset or power down the board. To do so, follow these instructions:
  1. Ensure that the autopilot is in manual mode (channel five toggle off) and GPS is connected
  2. Place a jumper cap on pins D6 and D7 (you can also connect a regular RC power switch to those pins if you want to control the autopilot from outside of the aircraft). Ensure that your aileron and elevator sticks are in the center position, and power on the board.
  3. The yellow status LED will blink for a few seconds as the autopilot programs the GPS for binary mode. Then the blue lock GPS will blink rapidly, which means the autopilot is waiting for GPS lock. You can now remove the jumper (or return the switch to the normal position)
  4. When the autopilot has established a GPS lock it will move the rudder. Note that ArduPilot puts the EM406 into binary mode, which disables the red LED on that module, so it will not blink.
  5. You’re now ready to fly! Press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
  6. ArduPilot 2.0 supports two autonomous modes: waypoint and return-to-launch (RTL). If you have a three-position toggle switch or a proportional dial on your RC transmitter, the middle position is Waypoint Mode and the up (or full clockwise) position is RTL Mode. These can be changed in the software if desired. The Mode LED on the ArduPilot board will light up with it is in Waypoint Mode.
  7. To use fly-by-wire mode (just stabilization, like the FMA Co-Pilot), simply disconnect the GPS. ArduPilot also automatically switches into stabilazation mode if it ever loses GPS lock.
ArduPilot 2.0 (no Z sensor): This version requires that the IR sensor be calibrated in the field, on arriving and if the weather conditions change significantly:
  5. Holding the aircraft without obscuring the thermopile sensor, point the nose at the ground. Switch the autopilot on with your RC toggle switch. The elevator will move, signaling that the sensor has been calibrated.
  6. You’re now ready to fly! Switch the aircraft back into manual mode for launch, and press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
  7. ArduPilot 2.0 supports two autonomous modes: waypoint and return-to-launch (RTL). If you have a three-position toggle switch or a proportional dial on your RC transmitter, the middle position is Waypoint Mode and the up (or full clockwise) position is RTL Mode. These can be changed in the software if desired. The Mode LED on the ArduPilot board will light up with it is in Waypoint Mode.
  8. To use fly-by-wire mode (just stabilization, like the FMA Co-Pilot), simply disconnect the GPS. ArduPilot also automatically switches into stabilazation mode if it ever loses GPS lock.
  • Chris:After I have calibrated the ArduPilot 2.0 with nose point to ground,it found out that the rudder has effect on the orientation of the plane but elevator has mininal movement when testing on ground.Is it normal when on ground test ?
    Remco: ArduPilot 2.0 puts the EM406 in binary mode, which disables the LED on the module and stops generating NMEA sentences. That explains why it doesn't seem to work on ArduPilot 1.0 code. If you let the GPS module sit for a few days the internal capacitor will run out and it will return to its default NMEA mode and work as expected with ArduPilot 1.0. But for that reason we don't recommend that you share a GPS module between both code bases.
  • Hi Chris,
    After upgrading tho one of my adrupilot to 2.0.the gps module dont work anymore on my
    ather adrupilot 1.0.The light on the gps module burns weak and the blue light wont go on.please help.
    Remco
  • I see... thanks
    Saiful: It just acts like a FMA Co-Pilot.
  • Im lose about fly-by-wire. Can anyone explain in simple word what it is do? ;-)
    Dimitris: The middle position switch between waypoint and RTL mode is already in the software. It's in the first tab:
    if (Tx_Switch_Status()==0x02) //Check if we are in mode 2 (transmitter switch in middle position
    current_wp=Waypoint_Switcher(current_wp,wp_distance, wp_radius); //Waypoint switcher...
    wp_Mode=current_wp; //Checks if we are in Waypoint or RTL...
  • Are these features already included in code 2.0? Are there some sentences that need to be uncommented in order to activate them?
    Dimitris
    Dimitris: No, that is not the way it's currently configured. But we do support three-position control, and the in-between position can be fly-by-wire. You can enable that either a three-position toggle switch, if you happen to have one, or by setting your Tx to mix two channels, as in the case of most Futabas.
    You need to mix channel 5 with channel 6. For example channel 5 will only switch between manual/auto, and channel 6 will switch between RTL/Waypoint. Or channel 5 can switch autopilot on and off, and channel 6 can switch between waypoint and fly by wire. The option is called "PMX 1"
  • Do we get fly-by-wire functionality (Co-pilot stabilization) when the ArduPilot is on manual mode (MUX off)?
