Hi guys,
I bought this little (cheap) GPS module months ago from an indigogo project. I have since received my GPS and was having troubles interfacing it to my APM 2.5.2. I was simply trying to output the serial data into the APM, not porting APM to the skytraq chip.
Here is where I posted my question, http://www.navspark.com.tw/forum/output-to-arducopter. The guys here are very helpful with the info I needed.
It seems that all I needed to do was connect the TXD1 pin (navspark) to the RX pin on the GPS socket (APM) GND to GND and Battery (in) to the 5v output from the GPS socket. Then change the output of the Navspark to 5hz.
I don't know if there is any benefit to running a Navspark over a Ublox, or weather the APM is geared to accept the Beidou sat signals.
If I have provided any wrong information or if you could provide further info, please let me know in comments below.
-Liam
Would be nice if they would combine the G2M1 with the SUP500RR. Still a go to test this combo out tomorrow.
Well, take a look at the LEA datasheet Page 6 : Max. Navigation Update rate LEA 6H : 2Hz ...
http://www.u-blox.com/images/downloads/Product_Docs/LEA-6_DataSheet...
So I guess, it probably doesn´t matter, since GPS assys like the 3DR V1.1,1.2 with the 6H are working good (despite the fact that concurrent GPS/GLONASS systems are ringing the bell in 2014)
Is 1Hz decent enough for a flight envelope of 20-40mph? The lea-6h I use for the primary is set to 5.
Sorry, I was wrong talking about the NMEA message rate, I meant the position update rate. The Venus viewer can read it, but not change it (like @ NavSpark GL) We need a Config program for the G2M1..still stays a great GPS for other purposes though.
@John Hutchinson: Thx for your post. I´have noticed, that you own as well the G2M1, which I own as well as the NAVSpark GL (still on the bench, but already working great)
My question is: How did you configure the G2M1 for the PIX ? With the NAVSPARK viewer, you can set Talker ID as well as BAUD rate, but not the NMEA message interval...as far as I tried .
With the u-center (which works as well as a viewer for the the NavSpark after enable debug messages), I am recognizing a blinking view with the G2M1, like some output interupt ß
Regards,gervais
Thanks John H for the additional info.
Efi Gy, use gnss viewer. Binary > Configure NMEA message interval. Change it and save sram + flash.
BTW, wired an HK 900MHz telemetry radio to the datalogging board, plugged in the raw board and put a power supply on it and now have a remote RTK base station!
Mark, are you familiar with using correction via RTKLib?
Liam,
Can please tell me how did you change the output frequency to 5hz?
rgds
