Variable Pitch Quad Rotor - M/UAV
DIY project ranging from a 600cc 120HP etec Ski-Doo engine, UltraSport 254 tail rotors, extruded aluminum blades from Vortech, aluminum / steel tube structural components, and a carbon fiber reinforced polymer monocoque frame.
In our project Multipilot Board we had develop HG3 a Variable Pitch Quad ... see my repository ... http://code.google.com/p/lnmultipilot10/ and the video of HG3
Regards
Roberto
Sometimes in actual helicopters, a loud bang is heard coming from the main transmission and loss of power occurs with warning alarms going off, and then right before ditching the rotorcraft, all the power comes back and noise goes away. Upon inspection after the incident, several teeth from main gears are chipped, and the transmission gets overhauled. Other times the pilot and passengers aren't so lucky.
I like that variable pitch motor! The rotor gear boxes I have operate on the same principal, but there is a collective bearing block that attaches to the center shaft to pull the pitch actuator up and down. Any ideas?
Nice project!
What are you going to use as clutch or one way bearing between the rotor and each drive chain?
Without that, after engine or bevel gear failure would be impossible to perform an autorotation.
Probably a good idea is to make a small version of you model using this type of motors, maintaining constant RPM and changing just the pitch. Well at least cheaper way to tune you code and test the electronics.
Good luck...
Torque is balanced by connecting the rotors to a capital H drivetrain. Rotors on the left side of the "H" will rotate clockwise, right of "H" will rotate counterclockwise. Main drive will occur at center of "H" drivetrain. At four blades per rotor and all rotors being mechanically linked, it will be interesting to find out what the minimum height to perform an autorotation will be. I'm sure that because of the size of the blades that autorotation will have to occur within a few feet of the ground. Luckily after making some calculations based on multiprop aircraft such as chinooks and osprey compared to other similarly sized helicopters, i can just tell the computer what to do in case of an emergency.
And you're right that a fixed pitch quad likely wouldn't work on the large scale. The only reason using speed control works well on the small scale is that it has very little momentum. But, if we're looking at this from a practical point of view, that doesn't explain the need for a full sized, variable pitch, quadrotor. Your argument seems to be that a quadrotor is more forgiving (of component failures?) and easier to use, but I don't really see how you get there. A normal heli can loose power entirely and autogyro down to the ground safely. Doubt you could do the same with a quad. The computer really has to be in complete control in order to maintain stability. Maybe you could loose a rotor and manage to compensate, but that's easier said than done when the only thing stopping you from spinning out of control is the balanced torque of the motors.
Which also brings up the question of how you plan to balance the torque. I assume all of your tail rotors are designed to spin the same direction. A quad with all the props spinning the same way is no better off than a heli without a tail rotor. Most quads have counter-rotating props to cancel eachother out. Tilting one or more props could do the trick, but that's yet another added complexity.
Honestly, I'd love to see an application for quads on the large scale. They're cool looking and a refreshingly different take on flying. But once you step away from the fixed pitch idea I just don't see the justification for it. This isnt a car. More rotors don't make it automatically more stable. I just don't see any benefits it has over a conventional heli, and it certainly comes with some disadvantages.
It'd look cool, yes, but does the machine you propose offer any advantages over a helicopter? Perhaps it'd be more agile, but is there even a need for that?
for paragliders you will find electric powersystems, 25kg, 10kW and a 14s40Ah is enough to reach 1000m AGL. four will do the job as a quadcopter..
its no problem to furnish two 25kW engines for my mostliked design: NASA-puffin ;)
with 2m props and a axiro-range extender it will offer a great envelope!
1
2
3
4
5
of 5 Next
