Video: FIRST ADRENALINE
I really enjoy making FPV videos. But recently we started producing and selling our aircraft to customers around the world, which has taken up so much time it's hard for us to produce enough videos to fit our weekly schedule. So it's very refreshing to see that at least our customers are having fun :) These are a couple of clips from two of our first customers doing their first ever FPV flights (zero prior FPV experience!). Enjoy!
  • in this video both. When we visited them we used our ground station which is a tracked antenna on a diversity. but most of the clips they shot themselves with their 14dbi single patch rx system, the one I've been using for years prior to the tracking.
  • Are these guys using an antenna tracking setup? Or just a stationary patch antenna/tripod setup?
  • yes, stock TX antenna.
  • Thanks trappy. I think a purchase of a delta wing is definitely on the books :).
    And the antenna used on the video Tx was the stock one that came with the lawmate?
  • Trappy, as always, best FPV videos ever! Great stuff!
  • yeah, they have plenty of R/C experience. Learning to fly it, and learning to fly it fast down the mountains is 2 different pairs of shoes obviously. I've learned R/C on a flying wing, it's much easier due to the "bank & yank" kind of flight. However, I suggest to start with something a little more docile like the Maxi Swift, or even a Zagi. There's also a handful of simulators out there that can help you get into R/C, which is essential before you move on to FPV. If you rush the R/C part, you'll never fully feel comfortable in FPV.
    The ground-antenna used is the 14dbi patch antenna available at most FPV hobby stores. It's pretty basic, cheap and a good beginner antenna.
    http://www.l-com.com/item.aspx?id=23181
  • Awesome stuff. You say no FPV experience.. does that mean they had RC experience? If not, how difficult is learning to fly on a delta wing?
    Also, do you happen to have any specs/datasheets/links on the antennas used here? Thanks.
    Keep posting the vids :).
  • The OSD info is shown on screen "analog" and sent "digitally" down to the ground station. The iOS app is claled "iTelemetry", it's a free download and tied to the system we use (immersionRC EzOSD, EzUHF). You can also receive all other information such as RSSI, Voltage, mAh consumed, speed, etc. Same applies to the windows application, obviously. If you want you can pipe the live-feed to your laptop and receive all information there. But we don't like bringing laptops out to the field.
  • Thanks, so this way all OSD info goes through the audio link instead of the vdo?
    What iOS app is used?
    Very interesting system.
  • yes, the current GPS coordinates are transferred via audio-link down the FPV stream. you can record that footage (we also sell a recorder) and then play it through an available windows application, which will give you the GPS coordinates. You can also connect an iPhone or iPad to the audio-stream and it will show you the plane position in real-time. this is even faster for recovery, as you can just grab the iPhone and start walking until the "Home" pin meets the "plane" pin :)
