Thanks to Pteryx for this great data set! In order to generate a geo-referenced NDVI / EVI / EVI2 Vegetation Index we need to fly the area of interest (AOI) with a visible (RGB) and full spectrum (RGB+NIR) camera. Once the RGB and RGB+NIR images are processed inside DroneMapper we have two orthomosaic results from which we can generate a pure NIR ortho. To do this, we use GDAL and the following command:
/usr/local/bin/gdal_calc.py -A VIS.tif -B NIRVIS.tif --outfile=nir.tif --calc="(A - B)"
Now that we have created our pure NIR orthomosaic we can use this to generate NDVI or other calculations using OTB in an automated fashion.
/usr/local/bin/otbcli_BandMath -il NIR.tif VIS.tif -out ndvi.tif -exp "ndvi(im2b1, im1b1)"
In order to process the orthomosaic tif files, they need to be the exact same size and pixel resolution. OTB also has many other useful commands for remote sensing work. The original flight and area of interest is 1.0 km sq @ 10 cm GSD.
Thanks -- JP @ DroneMapper
Hello. I am currently starting a research project which is focused on detecting the dead crops in a farmland using NDVI. I wish to derive the NDVI from the images and use computer vision to highlight the dead areas in an image. Can I use the regular images/videos taken from drones or do I need specific NIR images? Does anyone know of any datasets that I can use?
Please help me out, I'm totally new to this field. Please be my guiding light my lord, and I shall forever be in your debt :D
Cheers
...an NDVI generated from a NIR-G-B single camera system via UAV...
Great info! This was generated using open source tools and workflow (GDAL/OTB). Let me know if you'd like more details. I should have been more clear in my original post.. this is just one way to obtain this data, it is not the best method or most accurate. Anyone looking for a great open source remote sensing toolbox, check out OTB Orfeo .. the learning / compiling can be step but worth it. We've been tossing around the idea of building a field processing unit for offline/remote processing. Maybe I should do a kickstarter... eh? :)
wonderfull job guys!
Hi Rory,
Iam using my drone, for agro-environment maps as a part of my Job as well as my Phd thesis.
I think, to guarantee layers match from different sensors is a just a matter of output or mapping scale..
will try to explain with an example:
If your two orthomosaics (NIR and RGB) have 5cm/p spatial resolution (a leaf size) and your map, or image analysis is set, lets say 1:5000 scale ( usual for large crops) the final distinct output would be ~1.23 meter/pixel (bush size).
Also when you georeferencing the two mosaics you can see the total RMS error. Finaly combining the scale and RMS, you can resample the spatial resolution, using a desired method and then composite the bands to multiband image.
If you work with vegetation indices for mapping and several plants, you will be able to clearly distinquish if the results are right or wrong.
Again JP, excelent work!! iam doing the same thing using 3-4 (very expensive) software and own GIS rutines! I would certainly be happy to work with DroneMapper and more happy, if you release a field app, to give on site results!!
Regards
James
Creating orthomosaics of the same GSD and same AOI from the same flight is the best course of action to guarantee that the pixel bandmath matches. Certain tools have these checks built in. Of course, you'll probably experience more noise from lighting conditions/shadows and/or lack of good normalization routine as well.
Hi, the pixels between images are the same size. ~10 cm GSD
Each orthomosaic (VIS and NIRVIS) scene is the same size and GSD. 10772 x 12442 pixels.
The flight was completed with two different cameras and the geo-referenced orthomosaics were generated from the same flight. We provided a shapefile of the area of interest to our processing system and it clips the results to that AOI. This ensures you have the correct sized tifs to complete the BandMath.
Tools such as OTB won't let you process tifs of different sizes for ndvi/evi calculation. Thanks
@FlyingMerf.. I would love to get into doing this sort of analysis out in my area.. is there any good sites that show how to properly do vegetation stress analysis.. I like the modified camera approach as you probably would have a smaller payload then other methods.
me too! i think maybe tetra cam is closest possibility?
I hope someone will figure out how to make an affordable, light weight, true 4-band camera. It will have soooo many applications!
1
2
of 2 Next
