New SARQ frame . Testing today went well. Everything is waterproof.
Here at Lift Off U.A.V's we carry custom made to order ready to fly setups that require zero build time from you. So that means more time flying and filming and less time figuring out how to get setup.
https://www.youtube.com/watch?v=3BDch05XrB0&feature=youtube_gda...
Watch in HD
at the very least, make the diameter of the arms smaller and reduce that lip.
you can even angle the lip down to allow air flow.
If you want stability in free fall and in flight you should make the arms into a banana shape so that the bottom of the motors is above the top of the center, when falling the multirotor wont flip and the props will act as drag.
when in flight the lower cg will keep the copter stable increasing flight times.
Thanks again,
Charlie
weight is nothing to do with it, you have taken about 40% or the airflow and thrust from the prop and and forced it sideways because of the bloated frame, the air goes sideways into the downward airflow creating turbulent air under the prop and 40% less power from the motors than most frames which are in the realm or 5% or even less from under mounting the motor.
you are likely loosing a huge chunk of flight time! 20mins is good but it could be longer, if it really is 20, but that setup 20 mins sound unlikely with that frame
looks very very very inefficient
Nice!
Now the flight modes can be extended with a submarine mode... :-)
Amazing!!! Are you selling RTF Versions anywhere?
