Last time I introduced how to use manual operation mode for spraying. Today, I will continue to take the Z series holistic system as an example to share another work mode—A-B Route Operation Mode, which can form a straight route line between two points.
There are two methods can enter the AB operation mode:
Method 1:
1.Click Agri Assistant >Connect> H12/MK15 >Start
2.Complete the preflight inspection and unlock for takeoff in Attitude Mode.
3.After takeoff, fly to the field where you want to work. After the aircraft stabilizes, click “A” to enter the AB operation mode. Click the A near your side to add point A. Detailed flight parameters will appear on the screen. Set the parameters, then push the stick forward, fly the aircraft to the other side of the field and click “B” to add point B.
4.After adding point AB, click “Start”, then choose “To the left” or “To the right” then the aircraft can automatically identify the planned route.
Method 2:
1.Fly to the field where you want to work. After the aircraft stabilizes, move the left lever on the side close to you. Switch Attitude to Auto mode, and then fly to the A position to add point A , the detailed flight parameters will appear on the screen. After setting the parameters, push the lever forward, fly the aircraft to the other side to add point B.
2.After adding point A and B, fully push the right stick to the left or right, and the aircraft can automatically identify the planned route.
In the next article, I will introduce you the last spraying operation mode. If you have any question, welcome to share your opinion.
*The above steps are for reference only. Please refer to product use manual when using.
