  • Char of flitetest mentioned it in his Director Video as a KK2 Board
    But the processor core and hence math performance is exactly the same for a 328/2560, so we run into the same computational limitations when trying to make sense of the sensor data and calculate an AHRS solution. The performance gain from extra PWM hardware is marginal in this regard.
  • Which we then do through a 328 anyway... ;)
    @Lefebvre: Yes, that pretty much sums it up. The only thing that might make a difference is that the 1280/2560 has more hardware PWM channels, making it easier to drive servos/motors.
  • @John, really? I thought the 2560 had more power than a 328, 168, etc?  What does it have more of then? Just more IO and more RAM?
  • Thanks Dave.  That KK plus platform, sounds interesting.  Too bad it take some much hacking to get working.
    Also it answers the question Simon has about that that 5th input was:
  • I cant wait, Hobbyking I'm sure will keep this a reasonable price range which makes it even better.
    Lefebvre: Huge processor is a relative term. Any ATMega running at 16mhz has the same processing power that we currently have with the APM design, since we at restricted from using the DMP engine in the MPU-60x0 chip at the moment.
  • @Rigel. This is a really nice and compact serial LCD, it has some nice features that make it very easy to use http://cats-whisker.com/web/node/7
  • Someone needs to update the KK with some accelerometers.
