Who dares to buy one of these from China to test...
Thread happening at RCG http://www.rcgroups.com/forums/showthread.php?t=1198153
I wonder what exactly it is.
http://www.feiyudz.cn/en/Products/2009/12/08/92/
As Chris says, looks a bit like that Thai one, would there be any ground in doing a Chinese job in reverse and getting some and finding a better way of using them?? Maybe they are perfect??
This one does not have the pots for gains, but maybe its from the same place.
Detailed Product Description
Features
·Itegrated GPS receiver, three-axis MEMS gyroscope, pressure altimeter.
·16-channel GPS receiver, 4Hz output, 35 seconds fast positioning time and accuracy of 2.5 meters CEP.
·33HZ attitude inner loop control, 4HZ outer navigation controls.
·Mltiple-channel hybrid control output can be easily adjust the mixture control. Ajust neutral position just in time
·Three control modes: augmentation remote control, smart remote control and automatic navigation control.
·Three kinds of automatic navigation control modes: fixed flight mode, the mouse pointing flight patterns and route navigation mode.
·The ground station contains electronic map function software that can change the route and tasks online, real-time semi-autonomous remote control and can be real-time flight data recording and offline playback.
·Automatic and manual remote control integration, higher reliability and practicality, can compatible with all common facilities of RC remote control, and improve the fuction of servo output checking and remote protection.
·Available online to adjust and save all the control parameters, with stand-alone parameter adjustment software which is easy to use.
·Real-time telemetry flight data and records all telemetry data.
·Contains the control voltage monitoring, electric aircraft power voltage monitoring, GPS accuracy of detection, autopilot temperature detection and so on.
·Support RS-232 interface levels.
·Volume is 100 × 43 × 25mm, weight is 75 grams, power is .
Application
·Automatic navigate and pilot small and medium aircraft of non-layout form such as Regular, V tail, lifting flaps, ailerons and others.
·A variety of automatic navigation and driving.
·High-precision real-time data acquisition, image location of synchronization in the process of flying.
Technology Specifications
All refering value is at room temperature 25
http://glxinying.en.alibaba.com/productshowimg/283638321-209605532/XY_3_Autopilot.html
Some interesting looking airframes as well, some new and some we have seen before.
Surveyor_18F_UAV.jpg.html
  • $155 to the Chinese engineer in the video is like $5000 to us. He'll never be wealthy enough to afford that IMU as long as he lives, unless he becomes a party member or works for the Chinese version of Goldman Sachs.
    I have a friend/partner from Taiwan and he is trying to find more info from this firm. The RTH unit alone cost about 155 $. I fear it's made in a copy mashine..
  • The problem with all the demonstrations on the table is that they are not comparable to a "real" flight...
    In the end of the demo the system can reference to gravitation and magnetic field again and looks like no drift. All that counts is real flight data.
    Anyway the system looks like a solid piece of metal, not like a cheap thing. Anybody got a price range?
  • In the video, looks impressively immune to acceleration and drift.
    Your breaking new ground there Hooks!!! Well done
    About the thai RTH version it's made in China. I'll have one next week. Looks like it's comming from same firm.
    100$ + ems 90$ for the frame = testversion
  • T3
    Show me the base station software first...
  • I spy an STM32
