  • Thank you for the answer, Chris.
    Yes, I am new to Arduinos and UAVs and still learning as much as I can.
    The ArduPilot and ArduPilot Mega boards are both dual-processors boards, which is to say that they're a more complex board built around an Arduino core--one of the processors is an Arduino, the other is a failsafe/RC processor. They also have multiplexor chips and GPS connectors. Every try to hook up eight servos and eight RC input channels to an Arduino Pro Mini board? If so, you'll quickly realize why a custom board is the way to go.
  • @David Norwood
    I don't know your knowledge level, so forgive me if you were asking for a more specific answer.
    I believe the original ardupilot shares a common processor with the pro mini,(the "ardu") however the board has been customized to lend itself to UAV/Drone/Autopilot applications.
    Honestly, the cost difference between a pro-mini and an original ardupilot is so minimal, the correlation between helpful silkscreen info on the board and the ardupilot software would be sufficient to justify the cost difference to me. I don't know if the ardupilot code would work on a pro-mini or not.
    Now, the Mega is significantly more expensive than a Pro Mini, and for good reason. An ArduPilot Mega uses a much more powerful processor than the Pro Mini, and is more closely comparable to a new Arduino Mega, except that the new ArduPilot Mega has significant advantages over the Arduino Mega. I can't remember them off the top of my head, but the ability to oil pan the new ArduIMU oil pan is among them.
  • @ Masterbaker
    The short answer is IDK.
    I haven't looked up the data myself yet. Although the chips used on the Nintendo brand products are known, and their performance could be compared, I'm not sure what the clones/knockoffs use, and if that information is even readily available.
    To me: the ArduPilot/ArduIMU combo is nice because it's unofficially/officially supported through this forum/website.
    That's why I originally converted to the DIYDrones vs. the "Razor 9dof" IMU or trying to hack an IMU together myself from wii accessories. While both options seemed cheaper on paper, the cost savings didn't justify to me the added difficulty of navigating uncharted waters.
    Now that wii accessories are more well documented, and I'm more capable with electronics as a result of the excellent experiences I've had from working with the DIYDrones products, I just ordered some clones off of ebay to experiment with.
    It would be cool to have a performance vs. vibration benchmark shoot out across the board of current popular accelerometers and gyroscopes.
  • Is there a reason ArduPilot doesn't use the $20 Arduino Pro Mini?
  • great build !
    Earl
    I'm working on the firmware to port it on my board so is possible with a small investment to build a Multicopter :)
  • Any advantages / disadvantages over the ArduIMU besides a cheaper?
  • Norbert is such a great guy :-)))
