X8 flying wing
New wing from Skywalker factory >>X8 UAV platform<<
For those who want Long range / Long flying time / High payload the new X8 wing will get you there..
3689437228?profile=original3689437175?profile=original
3689437264?profile=original
The wing X8, will be released early 2012.
Wing span: 2122mm
Wing area: 80dm2
valid payload: 1000-2000g
X8 use KV730 2820 Motor, 40-60A ESC and 1260, 1280 prop
X8 skywalker wing
I'm already in love with this bird...
Now the X8 wing is ready in strong EPO foam
3689437192?profile=original
  • No unfortunatley Hobby King is stealing my money it has been months and they keep making up excuses like there was an inventory error. I have contacted them several times and i ordered back in november. Over 300 $ gone. This is the problem with buying from different countries they can steal youre money and get away with it because our gov has no juristiction. Please someone help me i will not let that money go down the drain. What do I do?
  • lots of comments.. how many have actually flown it?
    Mine should be here in three days. I will abuse it without expensive things in it.  then say something about it.
    Andrew yo said you were also trying to make one, any luck so far?
    X8 Wing EPS foam test version arrived.
    3689437192?profile=original3692334625?profile=originalRemember this version is still test version made in white EPS foam.
    X8 UAV wing
  • DARA: I am interested you have any photos or 3D image?
  • Dont mind the EPS black limited edition option!....dont plan on crashing much :)
    150-170 USD
    The final version will be made in White EPO foam. The black one is a test made in cheap EPS foam.
  • Black looks cool, but white gives more options. It's much easier to paint a white object black than the other way round.
    So I'd suggest to do a white EPO version first, and once the economics permit, to consider a black version.
    If you live in a hot clime, like me at the minute you would vote white to keep your electronics and the machine cooler when flying.
    Also they are easier to spot when you loose them.
  • Black!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
