I've finally perfected the X-Plane HIL for Ardupilot. This will be a feature on 2.6.3 which will be in beta today.
Flying Waypoints:
Here is missed waypoint detection: (I nudged the plane at the last second with the radio to miss the WPs.)
Here is fully auto take off and landing:
Here is the video of auto takeoff and landing:
Xplane and Ardupilot from Jason Short on Vimeo.
If you want to try this out you have to use some software to glue this all together.
Serproxy - used to talk serial to Ardupilot
Perl - to link Serproxy and X-Plane using "X-Plane.pl"
X-Plane 9 (the free version works fine, but it time limited)
I've only tested this on a Mac, so if anyone can try this on a PC, please let me know of changes to make, if any.
In the config header you will see a new ground station called GCS_Xplane (3). You must also use GPS_protocol 3 for ArduIMU.
Here is the Perl file:X-Plane.pl
Here is Windows Serproxy - Windows
Here is Mac Serproxy - Mac
in the config set:
newlines_to_nils=true
comm_baud=38400
Then set the com port accordingly
Go ahead and download 2.6.3 from the SVN. I'll post a beta soon as a download.
Moving forward I'd like to replace the Perl/Serproxy combination with a single C or Python based solution. If anyone can help, that would make it so much easier to set up!
Bonus:
http://diydrones.com/profiles/blogs/position-amp-wind-extended
Thanks for FlightGear Sim setup info, I agree that Sim testing is preferred to UAV flying away or into the ground. HW in loop can reveal any goofy behavior with little risk to equipment or people. I have flown FG with Rascal_110 in past using Jean-Louis Naudin's AP 2.47 AP and ArduFGControl 1.1 glue code on a HP laptop with Nvidia graphics. It worked great. but I could not get it going with AP 2.6
I have not flown ArduPilot 2.6_2 in the air since March due to not trusting my code or PID settings, but with Jason's new AP in loop Sim I can verify that I don't have up and down swapped, and PIDs are set pretty close. I have X-Plane 9 and prefer to run it on my MacBookPro.
Thank You Jason, keep the great updates & utilities coming...
--generic=socket,out,50,localhost,5500,udp,
Jason
If not, it is in websvn under ground/share/openpilotgcs/models
You can tag the Easystar directory and just download it from that interface. It is a 3DS with all the textures in separate files, the model is perfect, the textures could be a bit better how they fit together.
Thanks,
Jason
Use the one from OpenPilot, you will want AC3D which is what was used, import the 3DS and export it for Xplane (which uses AC3D for modelling).
I am bit annoyed that you appear to think this is a game changer when we (OpenPilot) have been doing it for a long time already and Paparazzi a long time before us. But I understand that being a marketing guy this is just how you roll but it does get other projects off-side. Far from being a game changer it is actually just common sense development, you *need* this if you are to become a solid platform otherwise bugs will take forever to spot, will be hard to reproduce and you end up with a lot of broken aircraft.
The Easystar model and the HITL Sim from OpenPilot can bee seen in this video:
http://openpilot.org/HITL_Simulation
I just added the nose up feature and have been able to perfectly land the included RC model in X-Plane. With Mega we should have some pretty good altitude precision.
I've been trying the other models included in X-Plane and it's a blast. Amazing piece of software at a great price.
Jason
Fraction of a second before touch down there should be little bit nose up or you can say elevator up so that landing is like manual.
In the simulator you always have precise altitude information, so you can do that :-))
1
2
3
4
of 4 Next
