Have you ever encountered these problems on battery-powered multi-rotors: it is very hard to get a 45 minutes flight time with 5KG payload at an altitude of 4500 meters, due to the thin air up there. Or it is almost impossible for the multicopter to fly for 1 hour in the cold winter at a minus 10-degree temperature because the battery voltage will drop dramatically in this case. YANGDA YD6-1600L gas-electric hybrid drone is designed to overcome these drone flight time limits. It is using one powerful gas-driven electricity generator which will give you continuous and stable power supply despite the high/low temperature or high altitude, will enable you to carry out long-range inspection, survey, aerial photography, search, rescue, and public safety applications.
Long flight time
When equipped with a 4L fuel tank, the YD6-1600L fuel-electric drone is able to fly 3 hours without payload.
High-performance and stable propulsion system
YD6-1600L hybrid power UAV is using T-Motor propulsion system, which is proved of high quality and stability.
Easy for transportation, quick to set up
Pluggable arms of YD6-1600L frame makes the drone is easy for transportation. The drone set up can be done in 5 minutes by a single man.
Backup battery
YD6-1600L hybrid drone provides 2 units 6S lipo batteries for 90 seconds emergency landing, just in case the gasoline-electric engine fails during the flight.
Multiple payload options
All YANGDA drone gimbal, camera and other payloads like drone megaphone can be installed on YD6-1600L hybrid UAV.
Photos
